H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by bain19 View Post
Originally posted by romcrazy View Post
What do you mean "images that havent worked"?
When I would flashed:- Load img file
- Leave the default check boxes in the burning tool(Erase Flash and Erase bootloader checked)\
- Click Start
- Plug in USB cable
- USB Device connects - Windows plays sound
- Flashing begins
- usb device quickly disconnect - Windows plays sound
- Usb Device connects again - Windows plays sound
- Flashing fails at 3%
Originally posted by romcrazy View PostAll those firmwares work for most of us. You may be having some other box or a clone.
Did you use, full format and erase bootloader?
Originally posted by rahzel View PostThe firmware that worked for your box has "lpddr3" in the filename... never seen an H96 Max X2 (or S905X2 box for that matter) have LPDDR3 instead of the usual DDR4. That would explain why the other firmwares don't work for your box, they are meant for the 4GB DDR4 box.
When I used those images I would get the error message 0x10401001 Romcode/BL2_boot stage error, at 3% when I flashed with USB Burning Tool v2.1.7.0
- Click Start
- Plug in USB cable
- Flashing begins
Erase Flash(normal Erase) and Erase bootloader both checked
Yeah its kind of strange even the amazon ad says DDr4
So I finally tried the TR99 Android 9 firmware and it's the ONLY firmware that doesn't have video stutters in the youtube mobile app for me, and I've literally tried them all. It's too bad that there aren't wifi drivers for this box, there's no root and the official google app doesn't seem to work on this firmware. The settings are also very basic, but it has the bare minimum. Hopefully a fully supported firmware gets released for our box, with more fleshed out settings, and upper and lower bars.
Originally posted by jeffta View PostI using burning card maker to instal roms on my devices.https://www.mediafire.com/file/v28g81wjx25dyk3/Burn_Card_Maker工具.rar Just buning rom on sd card.Power off device pres restart buton (3-5 sec) keep presing restart buton power on device a wait to instal roms.https://ibb.co/RTC1gm4
https://ibb.co/pQWVyvH this rom working on my h96 x2 2/16 https://ibb.co/nCMrhDK
Original rom https://drive.google.com/drive/folde...UGK1v7PrJ97kHZ
mod rom https://mega.nz/#!Wc8AgSqT!7PxNQgEsz...W_kAdr4pka0UYc
port rom x96 to h96 https://my.pcloud.com/publink/show?c...GsRbgAARLiUuyV
MECOOL KM9 TV box pie9 firmware https://chinagadgetsreviews.com/down...-tv-box-2.html
Has anyone tried this firmware?
QINTAIX Q9S PRO firmware https://chinagadgetsreviews.com/down...ro-tv-box.html
I tried this firmware but only Qintix logo in tv screen.My devices is 2/16 maybe working on 4/32 devices?Last edited by jeffta; 04 June 2019, 11:12.
Originally posted by jeffta View PostOriginal rom https://drive.google.com/drive/folde...UGK1v7PrJ97kHZ
X96Max_V311_4G_190302_to_H96MaxX2.img
my h96 max x2 2/16 working with this stock firmware (wifi, bluetooth, LAN...): https://drive.google.com/drive/folde...goZJdJ2WXKX6_M
But it often auto reboot when I'm using, so I try to find another firmware to test
Originally posted by romcrazy View PostDownload and flash from twrp. Download and put the zip in thumb drive. In twrp, select install. Select storage and choose your thumb drive. Select the new downloaded SuperSU zip. And swipe to flash it. After its done. Unplug and replug the box. If it boots fine, check app drawer. If all has gone well, SuperSU app will appear. If it hangs at boot or fails to boot, then boot twrp and restore your backup. Report after doing either of these.
https://s3-us-west-2.amazonaws.com/s...1705271822.zip
Originally posted by rahzel View PostSo I finally tried the TR99 Android 9 firmware and it's the ONLY firmware that doesn't have video stutters in the youtube mobile app for me, and I've literally tried them all. It's too bad that there aren't wifi drivers for this box, there's no root and the official google app doesn't seem to work on this firmware. The settings are also very basic, but it has the bare minimum. Hopefully a fully supported firmware gets released for our box, with more fleshed out settings, and upper and lower bars.
Originally posted by Shawncck View Post
Hi I have try flash the supersu.zip.... I can boot up after flashing.... But i still can't find the supersu app inside... What to do next... This is the file i flashed... SR3-SuperSU-v2.82-SR3-20170813133244. Hope it is correct cos the link you give cant work... I find this file from google... what to do next...
https://download.chainfire.eu/696/Su...etrieve_file=1
Then boot the device. And flash this second one.
After this, boot up and check for su in xbin. If its not present, then your device is unrooted.
There are currently 4341 users online. 1 members and 4340 guests.
