H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by rahzel View Post
Originally posted by Appdata View Post
Apparently, sergej_a_g isn't interested in porting it. '''I will not port'' but Google translator may have gotten it wrong.
Originally posted by sumeytek View Post
Mouse not move. please anybody can helphing. i calling company talking with whatsapp but him tell very basic
problem UNMODIFED SYSTEM PARTION
No idea about 2gb, but that hellish mixture is crap, play store wont work. You can try all the roms, and see which ones work for 2gb. Stay away from poison and hellish mixture.
[QUOTE=romcrazy;n772036]
Use a real mouse with usb. Use an air mouse. The stock remote also has mouse mode, but you cant hold and swipe with stock remote. USE A REAL MOUSE. IF you can, use a proper usb to usb wire to flash. Its cleaner.
thanks so much.
working wire mouse.
h96 max x2 64g really make me very tired. i dont know what happen i cant install image with TWRP
Guys, does Twitch app work fine for you all? I am on stock firmware 20190221 and it lags/freezes/stutters a lot. When I set resolution to 360p, it is a bit better, but it still lags. No difference if I use LAN or wifi. Also the image looks a bit grainy, like when it is not applicating HW acceleration and filters.
EDIT: it is needed to use older version of Twitch - the last version that works without lags is 7.3.0. All newer versions are laggyLast edited by Lapis; 12 May 2019, 17:31.
There are currently 2183 users online. 1 members and 2182 guests.
