H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by chenrp View PostFound it, pressed it before and while connecting the usb cable to the pc but nothing...
the px won?t recognize the box
has anyone tried flashing new img rom from a temporary twrp?
Try to disable driver signature enforcement on Windows 10 and then reinstall usb burning tool!
Sometimes drivers issues are so profound that even with uninstalling, your device will show up in hidden unconnected devices. So its better that when you uninstall UBT, you check the hidden devices from device manager and uninstall every instance of WORLD CUP DEVICE, also delete the driver present in windows. You can use usbdeview software for this also.
On a different note, why and how have I become a senior member? I have never contributed anything to freaktab how do they pick senior members?
Originally posted by chenrp View PostRestarted my windows 10 again with driver signe disabled (option 7)
and still nothing...
uninstalled and reinstalled the burning tool still nothing.
cant recognize the box
I using burning card maker to instal roms on my devices.https://www.mediafire.com/file/v28g81wjx25dyk3/Burn_Card_Maker工具.rar Just buning rom on sd card.Power off device pres restart buton (3-5 sec) keep presing restart buton power on device a wait to instal roms.https://ibb.co/RTC1gm4
https://ibb.co/pQWVyvH this rom working on my h96 x2 2/16 https://ibb.co/nCMrhDKLast edited by jeffta; 04 June 2019, 08:43.
There are currently 2962 users online. 2 members and 2960 guests.
