H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by romcrazy View PostIt doesn't matter. You can choose that folder itself. You will anyways browse to the innermost folder when you recover. You can try browsing to it from recovery to see how it works. Don't restore. Just reach the folder from recovery
Originally posted by romcrazy View PostYou worry a lot. Try. You will anyways browse to innermost folder. The one which has date in name. You can keep twrp folder or backup folder. You will anyways browse to it.
Originally posted by romcrazy View PostDid you tick all partitions when making backup? If yes. Then download SuperSU zip. Flash it. If it boots fine after flashing the zip and you see SuperSU app in app drawer, consider it success. If you can't boot, then boot twrp and restore your backup. Report after this.
Download and flash from twrp. Download and put the zip in thumb drive. In twrp, select install. Select storage and choose your thumb drive. Select the new downloaded SuperSU zip. And swipe to flash it. After its done. Unplug and replug the box. If it boots fine, check app drawer. If all has gone well, SuperSU app will appear. If it hangs at boot or fails to boot, then boot twrp and restore your backup. Report after doing either of these.
Originally posted by romcrazy View PostDownload and flash from twrp. Download and put the zip in thumb drive. In twrp, select install. Select storage and choose your thumb drive. Select the new downloaded SuperSU zip. And swipe to flash it. After its done. Unplug and replug the box. If it boots fine, check app drawer. If all has gone well, SuperSU app will appear. If it hangs at boot or fails to boot, then boot twrp and restore your backup. Report after doing either of these.
https://s3-us-west-2.amazonaws.com/s...1705271822.zip
Originally posted by Shawncck View Post
Thanks alot. I will try and report back.
https://download.chainfire.eu/696/Su...etrieve_file=1
Or This one is latest.
Originally posted by chenrp View PostIt this video the update is done without pressing the reset button!!!
https://m.youtube.com/watch?v=u1A8nbbVyBs
picked up this "H96 MAX X2" off of amazon recently and I've only been able to find one firmware that has worked on the device
I found the firmware here "aml_s905x2_H96Max_4g_mac_wifi_lpddr3_20190305" ; Other link to firmware for reference here
Silkscreen on the actual board say:- s70-905x2-v3
- 2019-02-18
Images that havent worked:- X96Max_V311_4G_190302_to_H96MaxX2
- H96_Max_X2_s905x2_4g_20190114
- XTMOD_GT1MINI_1.0_PUBLIC_to_aml_s905x2_H96MaxX2_4g-Multi-port hellish mixture
- S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13.58
- aml_s905x2_X2_tubi_4g_mac_wifi_20181117
- u215.T10_PRO_4G_AP6330_100M_8.1.2019.02.20.17.02
At one point I bricked the device but I was able to short out the nand and flash it
Nand pins here
Pic's of board
Does anyone know what other images I can use ?
If your software and driver is setup correctly and wire is good quality, your flashing will be flawless.
Originally posted by bain19 View Postpicked up this "H96 MAX X2" off of amazon recently and I've only been able to find one firmware that has worked on the device
- 2019-02-18
Nand pins here
Pic's of board
All those firmwares work for most of us. You may be having some other box or a clone.
Did you use, full format and erase bootloader?
There are currently 2206 users online. 3 members and 2203 guests.
