H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by jeffta View Post
Originally posted by Shawncck View Post
Hi which rom did u use? After flashing the box is not root? Does it suit for 4gb/32gb? I am looking for a rom that does not have root after flashing.
Yes this firmware will work for the 4GB H96 Max X2, but the firmware is originally for the TR99 X2 and our wifi drivers aren't included, but ethernet works.
And yes, this firmware comes unrooted.
I think I'm gonna use this firmware until something better comes out.
Originally posted by rahzel View Posthttps://mega.nz/#!L3QWESDJ!vL8gD1E9N...zsMcgxb8MN4L28
You cant expect wifi driver porting into android 9 pie. Wifi porting for oreo is what people are succeeding in. Pie will need source code release from amlogic for modding. Its system architecture is completely different from pie.
romcrazy can you help me? My box is H96 Max X2 2/16, I was try to flash this firmware: X96Max_V311_4G_190302_to_H96MaxX2 and it working smooth but do not have WiFi.
This is stock firmware but it often auto reboot when I'm using: https://drive.google.com/drive/folde...goZJdJ2WXKX6_M
Originally posted by romcrazy View Post
Flash this one then. If flashing this gives an error, you will need to restore your backup. If no error then proceed below
https://download.chainfire.eu/696/Su...etrieve_file=1
Then boot the device. And flash this second one.
After this, boot up and check for su in xbin. If its not present, then your device is unrooted.
Any other way after i done restoring?
Hi My box failed after flashing the first file.... It keep logo then become black screen... Cant go into android screen... I am restoring now....
I have done restoring. Any other way to unroot it? If not then maybe i can try the unroot rom. Any other issue w the unroot rom beside the wifi issue?
We have other methods for unrooting also we are first trying to find the symptom. You can use the pie rom its unrooted but wifi wont work.
On a different note, dependence on a specific app for TV is absurd. What happens when the app goes offline? Better use kodi with addons. There are many addons to watch live tv from across the world. I use deceit addon in kodi. It gives me live tv from many countries.
Flash this second link
How to verify if it is indeed unroot? This tv app is under subscription. I paid monthly subscription. Is a local government company which won't go offline. I need it to be working on this box.
There are currently 2571 users online. 2 members and 2569 guests.
