If you don't have another one just make one from 2 old usb cables!
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by romcrazy View Post
You can unroot any box any firmware yourself. All standard firmwares try to provide root, its your job to unroot it.
Do you have a way to unroot this box?
Originally posted by Shawncck View Post
Are u able to unroot your h96 max x2? Do teach me if you have a way.... Thanks
I agree some are rooted in a way that proves very difficult to unroot. but if you have adb knowledge every root can be removed.
Please post the screenshot of the root app you have. or app drawer. we dont know what we are dealing with.
My h96 max x2 came rooted... And i couldnt find the app that root it.... Is there a way? I do not have adb knowledge but would love to learn if someone is willing to guide me... Tia...
Also, out of curiousity. Why is unrooting needed for you? Any specific troubles?
screenshot of root app?
Sorry how to screenshot of root app? I cant find any app that root my box... I want to install a TV application... When run, it say my box is rooted and it can only run on unroot box... That is the reason.... I cant find supersu app in box... I install magisk use magisk hide but do not work.... So i want to completely remove the root... but i do not know how... I tot if there is a rom which is unroot, then i just flash it....
Install es file explorer. And open your device root storage. If su is present in system/bin then its rooted with supersu. if its present in system/xbin then magisk will work (highly unlikely since you have tried magisk already). If its not found in both these locations, there are other ways.
before attempting anything. make sure you can get back to this current point. If you screw up, you must have a way back. Either get familiar with flashing img firmwares or make your backup with twrp recovery.
Hi, I found su file in system/xbin.... Meaning i should be able to unroot using magisk? I try magisk but do not work... My safetynet check failed and my tv application stated my box is root... Any guidance? And can i check how to backup my box in case every gone haywire? TWRP recovery i did read up but wasnt sure how to go about doing the backup... And how to recover in case my box got brick...
First get your backup made. Dont go around trying stuff without backing up your current system. Read this thread you will find the recovery and means to boot that recovery. Make your backup. And then we will tell you further what to do. Hint: Magisk will work.
And one question how to recover with the backup? It seems that this thread show alot on backing up but nothing to show on recovery if the system brick... Can guide? thanks..
I saw alot in this thread.... do the backup using twrp w sd card right? But the link for the recovery.img is not working... file not found... i need that to boot right?
And one question how to recover with the backup? It seems that this thread show alot on backing up but nothing to show on recovery if the system brick... Can guide? thanks..H96 MAX X2 Amlogic S905X2 Android 8.1 4GB DDR4 32GB eMMC TV Box Dual Band WiFi LAN Bluetooth USB3.0 HDMI (http://bit.ly/2DeeAQr) Click image for larger version
Page 23. You should really read the thread. thats how we all learn. Use a usb flash drive. As long as you can boot into recovery from sdcard or usb flash drive and have your backup folder, you can recover.
And you cant brick your box. Believe me I tried.
There are currently 2639 users online. 0 members and 2639 guests.
