H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
I have never encountered this. Either someone else who has installed the same rom could help you, or you could try flashing same rom again and flash zip again. Or if no one helps in 2 days, then I will flash this rom and see what is the issue. You can also try to flash supersu zip and see if it flashes fine, you must make sure you are able to flash stock rom first so that you can revert back. Or make a backup first.
Originally posted by siriano12 View Postcould you send me the magisk file you use? I have tried the versions from 18 to 19 without success.
Appdata is telling you you can use supersu zip. then open supersu app goto settings and select, full unroot. Then flashing magisk zip will give you magisk root.
Originally posted by siriano12 View PostI have abandoned for the moment HK1, I am testing the T95x2 port with good results.
https://4pda.ru/forum/index.php?show...ost&p=84277854
I have tested every rom on 4pda, but I get confused which was which. I do however have seen every rom freezing hanging or not waking up and every other small problem here and there.
https://4pda.ru/forum/index.php?showtopic=933263 this is the thread where all our roms are located. The ones mentioned in first post work almost fine. As you scroll the thread you find other ports too some of which come with their problems, like wifi or bt or play store not working.
My favorite rom till date has been People's firmware created by Sasvlad https://4pda.ru/forum/index.php?showuser=71863 the rom was ported to our device by sergej_a_g https://4pda.ru/forum/index.php?showuser=566658
Link to the post: https://4pda.ru/forum/index.php?show...ost&p=81839450
Direct link to the rom: https://4pda.ru/pages/go/?u=https%3A...qGg&e=81839450
/snip
1. People's firmware
2. HK1 Pro
3. X96 v311
But all of them are pretty good.
Two issues I have with all firmwares are that 60fps videos in the mobile youtube app (playstore version) stutter the odd time for me. And the other issue is that youtube for android TV plays 60fps videos stutter free, but using any version newer than 2.00.19 keeps saying "Unfortunately youtube has closed".
Hi All, My dad has the H96 Pro from last year - My FIL has just bought the H96 MAX 4/32.
No matter what APK i put on the device to stream movies it just crashes - white screen and then goes back to the main menu of the device.
My dads works perfectly.
ALWAYS the way - I've been banging on about this box and for some reason he has just opened it out the box and cannot get any APK's to work.
Can anyone help please?
Originally posted by Dav091 View PostHi All, My dad has the H96 Pro from last year - My FIL has just bought the H96 MAX 4/32.
I just got this box recently in 2/16 GB version. What is the best firmware for it? I see most of the people like HK1 Pro here, while people on Russian 4pda forum like X96Max port.
Is HK1 suitable also for 2 GB RAM variants? What is better there than in stock ROM - is it worth upgrading? Does it have OTA updates?
There are currently 2222 users online. 1 members and 2221 guests.
