H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
    romcrazy
    thank you very much for your support , what i need for flash the tv box ? just now you told me that i must have working knowledge to flashing roms from laptop ?
      Originally posted by youyou2010 View Post
      romcrazy
      Read and follow.
      This firmware is for the H96 MAX X2 4/32Gb and 4/64Gb models only. Do not attempt to use it on any other device. They are not for ANY other model, even if it has a similar name, they will not work and could damage your machine. Do not flash these files if you do not know which device you have...
      Make sure you get a good cable. Bad cables usually give errors. Get cable from local market where you can exchange easily and get better ones if it doesn't work. Ask for a data cable.
        ok , but i can do backuup , and h96 max x2 iis rooteed butt x96 maax not rooteed ,,?
          Doesn't matter. You can gain root and also remove root at will. the twrp recovery lets you flash anything to system.
            thank you but what's twrp recovery ? , you know when i contact a seller of aliexpress he said me to buy a news alimentation adaptor 5v2a , do you have any idea ? its probably the problem from adaptor ? what do you think
              The best so far firmware is this : S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13.58
                gatos814
                you tested it ? how much the firmware you are test
                  youyou2010
                  i have the same problem with h96max x2 ... hang and restart a lot of problem and i have change adapter 5v 2a and 5v 3a same problem i have to try almost all firmware same problem because of testing several firmware and changing each time the cable usb i burned the usb port of the h96max and now i flash with the sd card
                  the only way to fix it is the two firmware "S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13. 58"
                  "X96Max_V311_4G_190302_to_H96MaxX2"
                  work well without problems ...
                    aouamed
                    thank you for your support ,then the adpator this is not the problem , what the firmware you used
                      here is the link
                      Посмотреть и скачать с Яндекс Диска
                        is it stable ? no freez ? no block ?
                          before i flash the h96 max x2 , can i make a backup ?
                            Originally posted by romcrazy View Post
                            Use the Amlogic customization tool. Although I am not sure, if the repacked rom will boot or not since I have v 5.5. But updated v 6.0 is available and people report it working.
                            Also, check vendor/etc folder, there is a file called bootvideo
                            That is the file you need to replace. I am not sure whether you need mp4 or which format. I would play safe and use an mp4 video. Rename it to remove the .mp4 part. And check permissions of original file before you remove it. You will need to give new video, same permissions. There are apps available to change the video with root.
                            Please be advised you must know how to flash firmwares, so that you can return to normal if you mess it up. Make a twrp backup just in case.
                            Indeed, replacing /system/vendor/etc/bootvideo works like a charm. Thanks
                              yes stable and no freez no block
                              me I do not do packup I direct flash...
                                when you flash with new firmware
                                you can do backup that the firmware contains TWRP_3.2.3 the latest version to make a backup
                                sorry for the bad english translation
