H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by gale View Post
Originally posted by gale View PostThe picture is not clear when on 4K TV have 1080p. Just like when you have a 720p on 1080p TV. 4K is a problem on the original firmware and HK1. At GT 1 mini 113 the launcher that not shows the location, android tv youtube 2.02.08 ejected constant message that has stopped working.
You could try other roms too if beelink doesn't work for you. Dont use hellish mixture though it has same launcher as beelink and same location issue.
Originally posted by romcrazy View Post
Oh yes beelink has the youtube app stopped message too. Can I ask and this is because I really dont know my box experience is just a week old, are many movies coming in 4k now is it time for me to upgrade my tv? and although i used android tv youtube i didnt understand why we need it when regular youtube app is available. about the location, you could use previous version of launcher i think that should work fine, you might be able to replace stock beelink launcher in system apps but it has a whole messed up permission scenario that I have never tried. I myself would just change the launcher i used nova on stock, but later got leanback from xda although its good it doesnt let you see all apps together. Which launcher would you recommend? and how are android tv launcher better than normal mobile launchers?
Youtube 2:02:08 for what he is doing 4K and there is an option link with tv code. LightHome launcher has the same problem on all Beelink android devices. The problem is solved by a few days, when for the GT1 mini released a new firmware. Lighthome 1.1.4 apk that I pulled out of the new firmware instaled System / app but still the same problem. 1080p TV is enough.
New USB Burning Tool 2.1.7.0 and latest firmware dated 20190114
https://forum.xda-developers.com/and...t3885871/page4
Originally posted by gale View PostNew USB Burning Tool 2.1.7.0 and latest firmware dated 20190114
No problems on my computer.
Originally posted by Charlie_Boy View Post
Windows blocked access to this file. You sure it's not a trojan?
Originally posted by romcrazy View PostCan the developers please tell me how to add wifi drivers to custom roms? Most roms seem to boot up fine with working air mouse and keyboard but wifi doesn't work. If I unpack the img and replace vendor/etc/wifi folder from stock rom will it start detecting wifi?
Then change the wifi settings in the dtb file.
You also need to add the userspace drivers to the system image.
Perhaps you also need to make changes to the boot image.
You have to build a new kernel with a new wifi driver.
There are currently 2988 users online. 0 members and 2988 guests.
