-901f-00c04fb951ed} 0x00000198 [11:55:29 205][HUB5-1][Inf]--Connect path=Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836/P0/P0 [11:55:29 205][HUB5-1][Inf]--Start burning... [11:55:29 267][HUB5-1][Inf]--------------ERASE BOOTLOADER------------ [11:55:29 376][HUB5-1][Inf]--start SendIdentifyCmd [11:55:33 151][HUB5-1][Err]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning.
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by gatos814 View PostCode:
Originally posted by Charlie_Boy View Post
This is the error I get whatever I try.Code:-901f-00c04fb951ed} 0x00000198 [11:55:29 205][HUB5-1][Inf]--Connect path=Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836/P0/P0 [11:55:29 205][HUB5-1][Inf]--Start burning... [11:55:29 267][HUB5-1][Inf]--------------ERASE BOOTLOADER------------ [11:55:29 376][HUB5-1][Inf]--start SendIdentifyCmd [11:55:33 151][HUB5-1][Err]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning.
It seems you have some windows issues...
Try to update the drivers , also look here for this ''libusb0-dll:err'' :http://forum.eleksmaker.com/topic/10...usb0-dll-error
Good luck!
Successfully rooted 2/16 model using MAGISK!
Working recovery here: recovery u211 thanks Guest
1. Rename recoevery to recovery.img
2. Put recovery.img to root of micro-sd
3. Insert micros sd card into device
4. Keep pushing recovery button insode AV hole and keep pushing while pluggin in power supply
5. TWRP launches
Originally posted by soldiaz View PostSuccessfully rooted 2/16 model using MAGISK!
5. TWRP launches
Hmm...
Good luck!
All I can do now is return it to the seller who although is Chinese is based in London so not so much hassle. He sent me a link to the firmware for an entirely different machine so I don't think he will manage to flash it either. I don't want a refund, I like the hardware specs, so if he can provide me with a functional replacement I will be happy. Thanks anyway to everyone that tried.
Charlie_Boy : Do not understand.
That is what I got: You want to flash bootable twrp through twrp and exchange stock, right?
I did not try that but it is likely to work! But I would not do this since you can bootup TWRP anyway...
As far as I know the box is rooted when delivered so I do not need to root it.
Ok, understand.
Let everything as is!
You can easily bootup CUSTOM RECOVERY this way:
1. Get Magendanz TWRP build img.
2. put it on SD card root and insert it into box
3. Keep pushing recovery button inside AV hole while plugging power cord to box
4. Hold for another like 5 secs
5. Box boots into TWRP temporarily!
Box will boot into TWRP and let's you flash anything!
XTMOD_GT1MINI_1.0_PUBLIC_to_aml_s905x2_H96MaxX2_4g-Multi-port hellish mixture
https://yadi.sk/d/M2jafH9S8Qup7g
Got it from 4PDA!
Enjoy it!
There are currently 2307 users online. 5 members and 2302 guests.
