H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by sseleraci View PostPrevious version was fine, voice was working ( libaudio... replaced)
here is update version if you want to try.
https://yadi.sk/d/NbflXLKZKeiE6w
I tried in many ways to fix it (replacing files, editing etc) but unsuccessfuly.I think that somewhere I read that by replacing the boot partiition with the boot partition of another working rom this can be fixed.Is anybody aware of such a simple fix (with no other side effects)? And if this is correct can somebody make a backup with TWRP of his boot partition (e.g. from HK1 rom) and uploaded here? The size is about 16MB.
I just try 2rd rev rom ( before latest one), led light is correct but navigation bar always crash. I think I will go back to the really 1st one.
below is only my experiences;
1st rev: led light ok, no supersu, 4G of ram ok.
2rd rev: led light ok, navigation crash, no supersu, 4G of ram ok.
Latest: led light wrong, navigation bar crash sometimes, has supersu and 3-4 russian tv apps, aida detects only 1G of ram.
All of it, thanks to sergej for porting good rom.
Hello !
I try this one : https://forum.freaktab.com/forum/tv-...ndroid-8-1-atv
It works very well on my H96 Max X2 4/32 (ddr4) not ATV
I have try so many ROM.... Sometime, the wifi doesn't work (either the start with remote), sometime IPTV software crash.
I just begin to test, but everything seems OK (wifi, IPTV, remote, Youtub, Play store....). Fast and fluid and ATV 8.1.
Finally the best one but to be continued....
https://yadi.sk/d/NbflXLKZKeiE6w mod_GT_King_AT_V3.1B_to_H96Max_X2_4Gb_4_Gb_by_serg ej_a_g
h96max x2 4g 32g lpddr3 no problem
working good. I have tested.
Install with memory card.
Originally posted by kipir View Posthttps://yadi.sk/d/NbflXLKZKeiE6w mod_GT_King_AT_V3.1B_to_H96Max_X2_4Gb_4_Gb_by_serg ej_a_g
you do not have to unplug the plug. everything is working normally. Extension control turns off, opens.
- The color of led is reversed (red when ON - blue while OFF).If you do not have this maybe it is because of different box (mine is h96 max x2 4/64 8ddr3 /ddr4).
- The orginal remote contol works correctly at this version (both to shut down and turn on the box - no need to unplug it).
- There are some different apps / some of them in Russian.At least one of them can not be unistalled easily from apps (I suppose I can do it in another way since the box is rooted - SU app).Â
Originally posted by ath156 View Post
Not only the led is reversed in my case but also RAM is shown as 1GB (when it is 4GB) in AIDA64 and CPU-Z (as already mentioned by others before).I think I have to go back to the previous version.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
i tried to flash revolution rom posted on forum. During flash I unchecked flash bootloader and now my android box is not responding to usb connection. can someone guide me how can i revive my dead box? Attaching images of box for reference.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
OK.I tried this version of GTking and I have noted the following:
- There are some different apps / some of them in Russian.At least one of them can not be unistalled easily from apps (I suppose I can do it in another way since the box is rooted - SU app).?
There are currently 2052 users online. 1 members and 2051 guests.
