H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by soldiaz View Post
Originally posted by soldiaz View PostAlright, then I understood right.
So basicly Alvatech's patched img is (MAGISK patched) TWRP recovery img, right?
So then I could take this image and use it es recover img and repack...
This is Why the method romcrazy works, it is because of the Step to UNROOT device while device is running inside TWRP mounted SDcard.
romcrazy this method you detailed would be good in a "Knowledge&Tutirial" post.... if you could simplify it, don't explain why it works or how it works, just do a write up like "Add Magisk to S905X2" use this "File" do these steps "1..2..3..4..5" -- make as simple as possible so it doesn't get lost in translation, because for a lot of users of FreakTab -English is not primary language.
Originally posted by RiCkLaR_atvX View Post
You must delete all original ROOT(old ChinaRoot or SuperSU) files from stock/custom ROM if you want your Magisk.recovery.img to work inside a ROM.img that you personally customize.
But your first point stands perfectly. Soldiaz will need to unroot the stock rom before using this twrp img to get pre magisk rom.
Originally posted by RiCkLaR_atvX View Postromcrazy this method you detailed would be good in a "Knowledge&Tutirial" post.... if you could simplify it, don't explain why it works or how it works, just do a write up like "Add Magisk to S905X2" use this "File" do these steps "1..2..3..4..5" -- make as simple as possible so it doesn't get lost in translation, because for a lot of users of FreakTab -English is not primary language.
And in hindsight, soldiaz no your method might not work. Its not just a matter of replacing the recovery img. First, alvatech's zip fixes some permissions, which is seen on screen while flashing his zip. You might need to add some script that fixes those permissions.
It would be better, if you seek alvatech's help.
Here I thought freaktab is composed of english speakers just like 4pda is comprised of russians
sure? Few Android versions back I had 2 su apps, SU and Magisk and I was asked to chose one to control access..
i currently updated the device with following firmware aml_s905x2_9.0_H96Max_X2_mac_wifi_20190920 from firmware u214.H96Max_X2_4G_100M_9.0.2019.09.11.14.29.
In general settings there ii missing now any option for HDR settings as was under the firmware u214.H96Max_X2_4G_100M_9.0.2019.09.11.14.29. In the settings - device preferences - display there is only option for color depth settings an color spare settings.
Can you give me any advice.
Thanks in advance
Originally posted by romcrazy View Post
For sure you will be using only one. If you are okay with having 2 su apps thats your wish. If you go about removing supersu with root uninstaller or whatever, thats upto you. I gave you a way to add root to your box. How you go about experimenting with it is upto you. God gave you hands to hold things, what you hold with it is upto you.
Can I sideload through ADB?
Like this adb sideload ALVATECH_MAGISK_PATCH_MINI.zip
Originally posted by chenrp View PostIm having issues with youtube
Once every two days I have black screen with sound
only way to solve it is to hard reset the streame
please assist
Cheers!
Never use the YouTube app that come inside TVbox, always install Smart.YouTube, Vanced.YouTube, or NewPipe. If you already did then make sure you have updated which ever alternative YouTube apk that suits your preferences.
Cheers!
There are currently 2517 users online. 1 members and 2516 guests.
