H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by devitrified View Post
Sorry to ask but how do you do that? The original animation is not in system/media so there is no way to just go and replace it
Also, check vendor/etc folder, there is a file called bootvideo
That is the file you need to replace. I am not sure whether you need mp4 or which format. I would play safe and use an mp4 video. Rename it to remove the .mp4 part. And check permissions of original file before you remove it. You will need to give new video, same permissions. There are apps available to change the video with root.
Please be advised you must know how to flash firmwares, so that you can return to normal if you mess it up. Make a twrp backup just in case.
Originally posted by youyou2010 View Postplease the best firmware for tv box H96 MAX X2 4G 64G
Right now I am testing this one. https://4pda.ru/forum/index.php?show...ost&p=83459526
The first one is very stable, the second one is from x96 but working good till now. mouse is extra responsive on x96 firmware.
You can follow that thread it has good support for our box
Originally posted by youyou2010 View Postthe probleme is the box somtimes he reboot alone , and sometiems he blocked alone and its shut down alone
the seller told me to change the charger , , i didn't find the probleme ( adaptor or firmware )
Originally posted by youyou2010 View Posti find this :
S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13.58
X96Max_V311_4G_190302_to_H96MaxX2
Port_Х96Мах-Volksware v.0.2.0_by_Sasvlad_to_aml_s905x2_H96MaxX2_4g
GT1-mini_112N0_to_aml_s905x2_H96MaxX2_4g_32.7z
Poison_S905x2_V1.0_to_H96MaxX2_4g.7z
There are currently 2374 users online. 2 members and 2372 guests.
