H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Well there are several methods. I Quit thinking bout since it took me too long.
I read about method which works Like modules. So if correct configured it is possible to load any drivers contained in specific file dir.
that was best since you just push additional drivers in this direction and repack. Once done, no more problems
Originally posted by abood250 View PostHello guys I have two inquiries
Does this tv box can play the latest version of Netflix without problems?
What is the best performance this device or x96 max?
2. We have this device not x96max so I can't comment on x96 performance.
Originally posted by romcrazy View Post
1. Of course not, these chinese boxes are not given license by netflix and google drm widevine is level 3 which will let you play netflix in SD (540p only). This is common to every chinese box because greedy netflix has refused to give license to small companies. Even x96 wont play netflix at HD or 4kHD
Could you please confirm that by installing newest version of Netflix from here and try play videos without get error message and in HD?
This link
Note: you have to uninstall previous version before installing new one
This link
Hi All,
I had this 4/32 box delivered 2 days ago but found several issues.
My H96 Max X2 IR remote codes triggers other box functions at the same time:
1. Volume down key turns off my TV
2. Volume up key changes Sound profile at the same time. Every click cycles through Movie/Music/User/Sports etc...
3. Back key triggers up arrow at the same time
4. Help button brings up Settings
5. Apps button & TV Vol+ button trigger each other
On top of this the TV remote triggers my box functions:
1. TV Volume up activates Box Apps
2. TV Program guide activates Box AppInstaller
3. TV Subtitles mutes box volume
& more...
Any ideas ?
& more...
Any ideas ?
kindly note this testing was not done on stock firmware.
it was done on a rom ported on 4pda by sargej here is the link to the port. the firmware is rock stable with no lags freezes or stutter, it has two disadvantages, droid settings and lighthome launcher are in russian, but i found a fix for this, so now i have perfect firmware with everything in english and working launcher and no issues at all. even voice control works on this. If you hit download limit on the link, there are google drive links too further in the thread.
After a conversation i had with a member here i found a friend's subscription to test this netflix app
On H96 Max with HK1 PRO firmware the maximus resolution i took was 960 x 540 with 29970 fps which is not a HD resolution but a qHD !!!
So i'm wondering and i'm asking and romcrazy if you have check it with test pattern to see the real resolution?
Originally posted by gatos814 View PostAfter a conversation i had with a member here i found a friend's subscription to test this netflix app
You used netflix test videos? Or some other app?
Yes I am going to do that after 4 hours when i am home. I too found out the test videos given by netflix. Although to my eye it did look 1080p HD. But confirming it is better for all of us. I will put out my test today.
Choose , i think , aa test patterns and you will see!
Regards
There are currently 2813 users online. 2 members and 2811 guests.
