H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Ethernet is very good but wifi is terrible. I am thinking whether opening the box and adjusting the antenna will solve my problem or will i need to add external antenna? if latter, will it work with usb antenna because it already has an internal antenna why will it shift to usb antenna on its own? which makes me think i will have to remove internal one and solder new coaxial antenna.
Originally posted by Charlie_Boy View PostReturned my box to the dealer, was refunded, and an X96 Max is on its way to me. I hope for better luck with this model.
When you connect the box successfully, press the reset button and then hit start then you can let go of the reset button and it will flash 100% successfully.
Originally posted by romcrazy View Post
Sad that you sold it. You were just supposed to press reset button to get it to flash. I spent 8 hours doing all sorts of mistakes getting all sorts of errors yellow exclamation driver issues.
It is sad as I liked the box and I went through the hassle of returning it. I wish I could try that for myself.
Yes yesterday was 3rd day of me having the box and I decided to flash new firmware but being a newb i messed up from the word go. I did lots of mistakes and bricked it nicely, began worrying I had wasted my money cursing myself. Then I tried on another pc and it got detected and i found some hope but it was not flashing. I system restored my own pc 3 times because everytime error came, my device manager lost the ability to correctly identify it, foolish me realized after 3 restores that i should try once to press reset, and it got immediately detected and flashed the whole thing and i was left happy and embarrassed as I have always considered myself a pro at flashing phones. and then irony struck at me, and I remembered Trebor's advice to me back when i had opened my first thread on freaktab. I had asked people opinions about buying box, and Trebor said and I quote "With these boxes its not the destination but the journey that matters". So true and I laughed at myself because my journey had just begun. I dont think I have even scratched the surface yet. Its worth it. The madness, the rush, eureka moment is all true.
It is sad as I liked the box and I went through the hassle of returning it. I wish I could try that for myself.then after 5 errors, it got stuck at 9 % and i did a mistake of pulling the cord, that where my pc stopped detecting, showing exclamation yellow device description failed error. i used different machine and it detected correctly, so i proceeded to restore my machine and it got detected but on flashing, it errored at 2 % and then the exclamation yellow returned to haunt me, and i got into a loop, trying different options after every restore and getting errors followed by non detection. then i found a comment on xda about the reset thing and it worked. i got so happy i repeated the flash two times with all boxes checked to make sure it was not a one time fluke. i have made an account on 4pda now and 12 pages worth of advices and roms are there. beelink poison hellish mixture i will download tonight and tomorrow sunday will be a feast day with all the roms and my box.
Fyi : your latest reply to my comment is unapproved so i quoted this previous reply. And also, latest firmware is worse than first, flickers and air mouse drag problem which was not there in original stock are present in this. i will go back to original one i have that too but first i will try all the different roms and i will keep an eye on 4pda because there those crazy guys keep churning out ports. far ahead of xda who dont even know this box exists yet. thank
Yes that happened to me also. The box threw random errors at me. enum error, initialize ddr error, a bootloader erase error, the famous usb control error. it had too many errors for me at one point i even felt the box was taking its anger out on methen after 5 errors, it got stuck at 9 % and i did a mistake of pulling the cord, that where my pc stopped detecting, showing exclamation yellow device description failed error. i used different machine and it detected correctly, so i proceeded to restore my machine and it got detected but on flashing, it errored at 2 % and then the exclamation yellow returned to haunt me, and i got into a loop, trying different options after every restore and getting errors followed by non detection. then i found a comment on xda about the reset thing and it worked. i got so happy i repeated the flash two times with all boxes checked to make sure it was not a one time fluke. i have made an account on 4pda now and 12 pages worth of advices and roms are there. beelink poison hellish mixture i will download tonight and tomorrow sunday will be a feast day with all the roms and my box.
They think I am a spammer. Not so I have no connection with droidbox beyond being an old customer. Most of my purchases are made via Aliexpress or ****. Ah so I would've been left with further frustration due to more buggy firmware had I successfully upgraded. My main problem via the default firmware was that it lost mounts intermittently and everything was slow to open. When it did work though I was impressed, this wasn't often enough to keep.
If I may ask, what is droidbox? a company? i have heard this word thrown around on 4pda a lot.
Yes droidbox are a company that I bought an M8 from a few years ago. I think they split to form two separate companies and one became know as entertainment box or something. I have had no problems with customs but I am waiting for a torch baton which is late and may have been intercepted. I think some sellers do declare items as cheaper than they actually are or use gift but as I say, never had a problem. My box was a real bitch, the only advice the seller would give was do a system restore, which did nothing whatsoever.
I haven't used 4PDA but will in future, thanks for that.
There are currently 2492 users online. 0 members and 2492 guests.
