H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Anyone get frameskips once in a while in the playstore version of youtube with 1080p/60fps videos?
I'm using the stock firmware, dated 2.27 I think. Other than that, and the fact that the enter key doesn't work on the physical keyboard, the software is fairly stable. Don't know if it's worth flashing to a different ROM.
Originally posted by youyou2010 View Postit must a micro sd because i have a flash drive , and when i find the file recovery.img
H96 MAX X2 Amlogic S905X2 Android 8.1 4GB DDR4 32GB eMMC TV Box Dual Band WiFi LAN Bluetooth USB3.0 HDMI (http://bit.ly/2DeeAQr) Click image for larger version
Originally posted by rahzel View PostAnyone get frameskips once in a while in the playstore version of youtube with 1080p/60fps videos?
And we dont get frame skips on youtube.
Originally posted by romcrazy View Post
Find your recovery img from the two zips I have attached on previous page. There is another way to boot into recovery, if you will need, I will post here.
https://forum.freaktab.com/forum/tv-...768#post767768
Always worth flashing different rom. But there is a golden rule. If it works for you, dont mess with it.
So it the consensus that these are the two best firmwares for this box?
S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13. 58"
"X96Max_V311_4G_190302_to_H96MaxX2"
I wonder if the latter is the same as this one: https://androidpctv.com/firmware-h96-max-x2-03022019/
Anyone try this one? They both have the same date, both say 'V311' and both are 899MB.
Thanks.
The link is not working for me, my government has blocked such sites. if it says v311 then its indeed the latter. Apart from these two there is a people's firmware from sasvlad too but its launcher is in russian though we can change that.
Not sure if that will work for you.
edit: I downloaded both and they are indeed the same.Last edited by rahzel; 05 April 2019, 11:40.
Originally posted by rahzel View PostHere's the direct download link: https://dailyuploads.net/t0t63sn0uf3b
But if its the same, then I dont need to use that link. I wonder if that you you guy got into the twrp recovery
Originally posted by youyou2010 View Postromcrazy
thank you very much, but i am a fraid to break the firmware or the tv box because the firmware X96Max_V311_4G_190302_to_H96MaxX2 it working very well , if you want to tell me the seconde way ( when i boot to recovery i hope that i do not lose the all app or firmware )
Open it. There will be either of two things
1. If you see $ sign, type: ADB REBOOT RECOVERY. Hit enter. You will boot into recovery.
2. If you see # sign, type: REBOOT RECOVERY. Hit enter. You will boot into recovery.
If you see a blue color recovery with twrp logo, then you have it installed already and you can make your backup. If you have stock recovery, we shall continue from there. Do this and report please.
there is no best. It depends on your needs and usage. I find firmware from this one best. https://4pda.ru/forum/index.php?s=&s...ost&p=83459526
Right now I am testing this one. https://4pda.ru/forum/index.php?show...ost&p=83459526
The first one is very stable, the second one is from x96 but working good till now. mouse is extra responsive on x96 firmware.
You can follow that thread it has good support for our box
I flashed to this firmware late last night and have been using it for most of today. It is stable, but I'm experiencing the same frame skips in youtube the odd time that I was experiencing in the firmware that came with my box, dated 2.27.19. It doesn't happen that often but it is a bit annoying. The good news is that this box has a working enter key, something that was bugged on the other firmware.
I also still can't drag and drop items in certain situations. Nova launcher is completely locked. Evie I can at least drag and drop app shortcuts onto the home screen, but I can't add any widgets.
There are currently 1820 users online. 2 members and 1818 guests.
