Can you identify if your tv box motherboard is the same with the one who told about short pins?
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
I'm sorry gatos, I've just realised I've written my replies on the wrong thread!
I have two boxes I am trying to revive, an H96Pro Plus and a H96 MAX X2.
It is the Pro Plus that errors at 2%.
The MAX X2 is completely dead apart from a faint red light, after a flash where I unchecked 'Erase Bootloader' on bad advice!
It completed the image successfully but also bricked the box. It now isn't recognised by my laptop.
I did short the pins on the MAX X2 and yes, the mainboard looked the same as an earlier post showing where the pins were.
Apologies for the confusion!
Originally posted by shaft65 View PostI'm sorry gatos, I've just realised I've written my replies on the wrong thread!
2% means in simple words ... wrong firmware...!
Look the motherboard from your Pro Plus and if it says LP or something else should help you to identify the proper firmware...
Now for the MAX X2 the short pins ''trick'' should have bring your tv box in life...!
What else i can say....!
I don't know more...!
Originally posted by shaft65 View PostThanks for your help gatos, I am going to leave the Max X2 as it's under warranty.
I've tried so many ROM's for the 96Pro plus that other people with my box specs have had success with I'm beginning to wonder if one of the chips is faulty.
On ROM 'aml_s905x2_9.0_H96Max_X2_mac_wifi_20190521', I can bring up the regular Android settings as well as droid settings.
On ROM 'aml_s905x2_9.0_H96Max_X2_mac_wifi_20190 920', I can only bring up droid settings that appear on right side of screen. Is there no access to the regular Android settings? I hate just the droid settings on v20190920.
Originally posted by rahzel View PostNo, it's just an annoyance I don't want to deal with, even if it's infrequent.? I was happy with the GT king rom, so even the smallest issue will make me switch back.
Originally posted by sseleraci View PostLatest update gt king rom (nov22):
Aida shows only 1G of ram
Led light is wrong. Red is on, blue is off
5G wifi is fast 40-50/s
Is it only me?
I dont know how to report bugs to sergej. If anyone know please let me know.
I can't report any issues to him either as I don't have an account there and I don't speak russian so I can't even sign up.? I think someone reported the LED issue, but I don't think anyone mentioned the RAM.
Originally posted by ath156 View Post
I decided to try GT King Rom. One problem I found is that if you turn off the box then you cannot turn it on by the remote controller (you have to disconnect/reconnect the power cable).Although this is not a big problem for me as I already use a power switch to controll the box (I discoverd that it gives power to USB even if it is turned off - so a USB cooling fan I am using was working continously) it is still annoying.Is there any known fix for this?
Is it only me?
The original developer (Alvatech) has 2 versions of the GTking Rom for 2 different versions of GT1-mini box.Maybe there is the problem? Your box is LPDDR3 or 8DDR3?memory 4/64?
In the version I use the light (blue or red) is correct.Also Aida shows correctly 4GB.Can you give a link of the updated firmware?
here is update version if you want to try.
There are currently 2873 users online. 2 members and 2871 guests.
