You probably have used the HK1 Pro firmware and not the HK1 Plus!
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by dpk6200 View Postcan we flash H96 MAX X2 firmware on HK1 PLUS 4/32GB spaces seems same ?
https://www.aliexpress.com/item/3299...7f8168a54r6O6H
i've tried plenty of dif firmware including the latest factory one and still getting the same weak wifi as the firmware that came on it. so i'm guessing it's a hardware issue.. has anyone successfully increased wifi signal somehow, maybe some kind of antenna mod or something? it's a shame about the wifi, 2019 and they can't even get wifi right? smdh..
Yes, i can confirm, abysmal weak wifi signal on H96 MAX X2 4/64 Android 8.1, do we get some improvement with 9.0 firmware flash?
There is pigtail antena inside, glued to inside side of box with some small plastic square.. Cant figure out why is so weak?
Last hardware series of H96 from march, april, may, had better wifi..
Originally posted by Jole View PostYes, i can confirm, abysmal weak wifi signal on H96 MAX X2 4/64 Android 8.1, do we get some improvement with 9.0 firmware flash?
the firmware that was on it from the factory was super buggy to the point it would freeze randomly just while on the home screen forcing me to unplug the power. also videos would stutter while using hardware decoder and software decoder made everything look like it was filmed on a potato..
flashed them to the latest android 9 firmware from here https://drive.google.com/drive/folde...J-XHAImx91RH7z
fixed all my suttering and freezing issues. hardware decoder works great now and the boxes are overal "snappier"... however.. wifi did not improve from what i noticed. which is why i am fairly certain it's a hardware issue.
I will try that firmware on one of my boxes, and will see difference in wifi strenght, and overall performance. I did not have any problems or freezing with devices, only catastrofic wifi signal.. I had 6-7 devices H96 Max X2 4/64 for friends and family and tried them all and all have wifi problem..
Originally posted by romcrazy View PostDid anyone find out how to replace stock supersu root with magisk root?
Originally posted by gatos814 View Post
Originally posted by Jole View PostI have model H96 Max X2, like on attached picture, and I can't install Android 9.0, flash tool gives error.. Is there any other 9.0 rom to try?
It seems that you have lpddr3 version tv box and i think this is what you need :
There are currently 2823 users online. 1 members and 2822 guests.
