Edit: And now I can’t start the box!!!
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
The manufacturer released a new pie update that includes the lower navigation bar, but it seems unfinished and unpolished. The navigation bar stays white/transparent regardless, even on a white page, making it barely visible. There's notification shade and they removed the traditional android settings app and only include the somewhat limited settings app. I didn't proceed to setup the box as that was enough to make me go back to segej's N5Max port with upper and lower bars. There's some minor issues with the port, none of which affect me, so that's what I'll stick with for now.
But, if anyone wants to give it a shot, you can download it here: https://drive.google.com/drive/folde...BQ4iLC_wLEbLVV
Originally posted by buttboyboris View Post
I have the same problem?! Only get to 3% and then B12_boot stage error. Iam using the latest USB burning tool. Have tried different roms, different computers, but can’t get this to work:/
Give us more details about your tv box...!
What it says on the Build?
Maybe it's lpddr3 version!
Thanks for the qick reply! I think I have a lpddr3 version, I tried the new Pie release that was mentioned in this thread. The “b” version didn’t work but the other one did! Think it was the “A” release, if I understand it means I have a lpddr3? But does this mean that I can’t install any other rom? Would really like to install any of segej's ATV ports.....
Maybe sometime someone can make a port rom for these lpddr3 tv boxes!
Would be great! Found something named “People’s ATV” do you now where I could find the rom for 4/32? Hopefully it works
But i'm not a big fun of ATV OS !
That's why i don't know much about these ... !
But if you like look and at this place : https://forum.atvxperience.com/viewf...8f5778495af04f
Maybe you will find something useful!
Sorry ... again !
Maybe you will find something useful!Will check it out! You don’t know how I could make my box start apps in “tv mode”? Many spoof my device into thinking it’s a ATV box.
And know Iam stuck once again! Sorry for the “spam” of messages......
Iam on the new Android 9 and Iam trying to root the device with Magisk, but I can’t get it to work?! Downloaded Magiska manager and press “direct install”. Everything works and I reboot the device, but Magisk manager still tells me that Magiska isn’t installed?
Side-question: What ROMs do work with H96 max x2 4/32 ddr3?
Originally posted by buttboyboris View PostAnd know Iam stuck once again! Sorry for the “spam” of messages......
Originally posted by romcrazy View Post
The stock rom is already rooted by some chinese root, which prevents magisk usage. there is no workaround for this till date.
Hello i bought a H96 Max x2 (4gb ram, 32gb rom) 2 months ago from Banggood. It came with android 9.0. Today i saw that there is brand new October firmware from the company. I used Device Info HW to see my system in order to choose the right update. I saw u214 on board info so i should use u214 rom (8DDR3 version) right ? This one right ? : https://drive.google.com/drive/folde...J-XHAImx91RH7z
Thanks in advance.
My system screenshot :You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
First time i see this firmware version so i don't think i can identify the real version of your tv box!
But i can say with sure that till now the 4/32 tv box from banggood was an lpddr3 version!
And also , i'm sure that these things are changing time to time!
So , i think you should try both of the 2 versions and give us the ... results!
Don't worry nothing will be happened if you try the wrong version...!
Just flash the other one and everything will be ok!
There are currently 1600 users online. 0 members and 1600 guests.
