I also dont care for root, because I use kodi and it doesnt have any ads. But its always you know, cool and hip to have latest magisk. I use ethernet, still I beg in 4pda for working wifi. If its there, I should be able to use it, doesnt matter if I dont use it. It should be available.
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by romcrazy View Post
While flashing you should go for erase all instead of normal erase. Select erase bootloader also.And tick whether overwrite key. Make sure both mac and mac_wifi keys are selected.
And can i know overwrite both MAC means what? What is the impact?
Think of it like installing your windows. While formatting it, you get two options. Clean format or keep your files and settings install. Normal erase might leave a file or two behind. The key selection is for those who have flashed their device so many times that their regular configuration has gone haywire. Its always better to select complete format and with both keys. The chance of residual crap is very less this way. Plus it helps calm the nerves if you are paranoid like me.
Originally posted by Shawncck View Post
Hi, what is the different between erase bootloader and not erase? Will I be able to flash other rom again with erase bootloader?
Mac is your mac address. Your device has a unique mac address. If mac config gets messed due to multiple firmware flashes, your mac will become 00:00:00 and so on. It BT or WIFI or both will stop working.
Hi im new here.
o just receive the box yesterday. I just receive this box yesterday.. Its a great box but i found some issues
I cant connect to bluetooh i tried with a ps4 controller and with a lg g7 and xiaomi note 5 .. The devices not showing in the box and the box not showing in the cells..
a saw the bt adress is something like td:0:0:0:0:0 something like that o dont remember and i cant it right now ( im working ) i dont know if is a faulty software or hardware? .. I think the bt adress its bad? .. Its arrive with android 8.1 but i saw a new firmware with android 9.. Do you think the bt can working if flash a new firmware or its a faulty hardware? ... I can ask for a refund yet on amazon. But the seller has no longer stock for a replacement
You cant have magisk I told you earlier. You have system wide root already. If you dont want root, you can flash Unroot zip. You cant have magisk yet.
The box has no power light on. And I cant flash the box either. Is it a power supply failure? I couldn't start the box now with power.
Died. I just did a TWRP restore. After restore done, it appear a error stated no directory found. Then prompt me reboot. As usual i reboot and now unable to boot up.
How are you managing to break the box again and again? Try to plug box in pc. See if its LED lights up. You might need to use short pin method to get your box to flash again. Search google and youtube for shorting pins method.
There are currently 3112 users online. 0 members and 3112 guests.
