H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by Shawncck View Post
So the droid settings is in Russian? Modded English version for me means you change the droid setting to English already?
The second one from 4pda is a custom rom which originally has russian launcher and droid settings. When I flash it, I change its launcher and droid settings app and then I made the backup which I gave to you. If you flash it from 4pda link, you will get the original custom rom with russian launcher.
I would suggest you to flash our factory provided rom. That one and the lighthome launcher I posted. They are best together. AND BEST PART IS. OUR FACTORY ROM IS UNROOTED. THATS CHERRY ON CAKE FOR YOU UNROOT LOVER BOY.
Stock rom android 9. Second one. https://www.h96tvbox.com/content/6-Firmware-upgrade
Launcher (Install it from AppInstaller) https://aapks.com/apk/lighthome/
Russian custom rom which I gave you after modding. https://4pda.ru/forum/index.php?show...#entry81839450
Originally posted by romcrazy View Post
With what? I didnt find su. And I tried rooting with magisk, it was successful but magisk manager would always show, magisk is not installed. What is it rooted with? Maybe I could remove the stock root and root with magisk?
Originally posted by rahzel View PostNot sure what it's rooted with, but 3 of the apps I use that need root worked. They were also given root access by default, I didn't need to grant them access. Also confirmed with a root checker app, just to be 100% sure.
Just out of curiosity. What apps you use which require root? apart from ad removers?
Flash the file below in twrp if you wish to unroot. Please note this will remove root completely and even root checker will show unrooted device. Only downside is, I still havent been able to install magisk. So do it only if you wish to completely unroot.
Rooted or not doesn't bother me.
Originally posted by Appdata View PostWell, I must have had a bad flash with Pie, it's not recognizing my ethernet and wireless is barely working.
Originally posted by rahzel View Postit has SMB support. It also has root access, and I use it to fix the keyboard config file by changing key 28 to ENTER. .
SMB support for NAS drive? or am i confusing it with something else? And how do you change keyboard config file? Step by step guide please.
To fix the enter key, follow this: https://forum.freaktab.com/forum/tv-...l-keyboard-fix
Note: If you plan on using X-plore as well, once you give the app root access, you also have to change the root access settings to give x-plore full root control, allowing it to make changes to read-only files/folders (it's in the configuration/settings of the app) -- otherwise you won't be able to save the changes to the .kl file. If you use ES file explorer, outside of giving the app root access, I don't think you have to change any other settings.
Note 2: Once you 'fix' the keyboard file, you'll have to restart the box for the changes to go in effect.
Originally posted by rahzel View PostYeah I have a USB drive plugged into my router, and I use x-plore on my android boxes and phone to view/transfer files between devices.
While flashing you should go for erase all instead of normal erase. Select erase bootloader also.And tick whether overwrite key. Make sure both mac and mac_wifi keys are selected.
As for Magisk, yeah I don't really care... whatever root comes with the box is good enough for me. I basically only use it to fix the keyboard and adaway.
There are currently 2416 users online. 0 members and 2416 guests.
