H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by youyou2010 View Post
Originally posted by Shawncck View Post
Originally posted by romcrazy View Post
No. And there will never be. If you are one of those legal official prime netflix guys, you are better of getting official google certified android box. like shield or mi box. You could get mecool but they have been decertified by netflix. you need widevine L1 for netflix. Our chinese boxes are L3. These boxes are for cheap sods like me, who get everything for free. And we dont get bullied by big corps like netflix. We make our own way.
Always. Thats why we got you to make backup first thing. Keep it safe. It will be a way to get back to normal if you get lost on the flashing highway.
I learn so much from you and most important u help me with my TV app that i almost give up.
You are android expert. Really appreciated your help. TYVM.
Btw l thinking to get another android box for my room, any recommended box beside this h96 max x2. Mecool is gd?
Great. Will learn flash when cable is here.
This guy on youtube reviews many boxes. He has a whole chart ranking various boxes. Check his channel out and listen to his indepth reviews before you buy
i dont know what to recommend but dont buy h96 maxx2 its wifi is bad. x96 a95 all seem to have good wifi
[QUOTE=romcrazy;n774815]
thank you for your support
Now just like supersu, we will try to achieve proper root with magisk before unrooting properly. So flash magisk zip from twrp.
But I have used those steps and my sdcard gets prepared fine. Just when I put it in box and use reset button to boot from sdcard, green android appears for some seconds and vanishes. Out of infinite times that I have tried, only once did I manage to flash HK1 pro this way. And till date I dont know what I did differently to achieve it. I would appreciate a full video.
This is the latest stock firmware for H96 MAX X2 which is partly unroot and ready for Magisk!
It has only busybox which you can easily erase after installing Magisk!
Of course with the Magisk you can easily fully unroot it or hide it and use some certain apps which don't work with root !
Install it via latest usb burning tool!
Use this TWRP : https://onedrive.live.com/?authkey=%...122709&o=OneUp
for installing the latest stable Magisk from Downloads section :
Enjoy it!
Originally posted by bain19 View Postpicked up this "H96 MAX X2" off of amazon recently and I've only been able to find one firmware that has worked on the device
I found the firmware here "aml_s905x2_H96Max_4g_mac_wifi_lpddr3_20190305" ; Other link to firmware for reference here
Silkscreen on the actual board say:- s70-905x2-v3
- 2019-02-18
Images that havent worked:- X96Max_V311_4G_190302_to_H96MaxX2
- H96_Max_X2_s905x2_4g_20190114
- XTMOD_GT1MINI_1.0_PUBLIC_to_aml_s905x2_H96MaxX2_4g-Multi-port hellish mixture
- S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13.58
- aml_s905x2_X2_tubi_4g_mac_wifi_20181117
- u215.T10_PRO_4G_AP6330_100M_8.1.2019.02.20.17.02
At one point I bricked the device but I was able to short out the nand and flash it
Nand pins here
Pic's of board
Does anyone know what other images I can use ?
Originally posted by chenrp View Post
No search for the mobile version
what rom would you recommend for h96 max x2 with WiFi?
https://forum.freaktab.com/forum/tv-...418#post774418
That post is a bit dated, here is the latest official for the H96 Max X2: https://drive.google.com/drive/folde...goZJdJ2WXKX6_M
And here are a few more that work.
https://chinagadgetsreviews.com/down...ro-tv-box.html
To me (not including the one and only ATV rom) they're all pretty much the same, save for the launchers.
Originally posted by rahzel View PostThere are many posted in this thread that work well. Here's a good start:
i want something clean, nexus like (not atv as I?m using a mouse)
There are currently 3213 users online. 0 members and 3213 guests.
