H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by diegofreak View PostWhat should I do with those pins? cut them? unite them? , I appreciate your help.So do the following steps:
1. Start USB Burning Tool and load your ".img" file. Press "START" and connect the 1 end of the USB-A cable to your PC/laptop.
2. Leave your box bare (nothing connected to it). While shorting the 2 pins connect the other end of the cable to your box. Wait 2-4 seconds, until "burning" process starts and then stop shorting the pins.
Good Luck
Originally posted by ath156 View PostNO !! Of course connect them while using UBT. To connect them you may even use a paper clip. Open and leave its 2 ends at a distance equal to that of the 2 pins. Better insulate the part of the paper clip that your fingers are going to beSo do the following steps:
Good Luck
Thanks friend, you saved the day it worked perfect and the first time, I returned to the original rom of this box
Originally posted by minonano View Post
diegofreak , any way of downloading the pic showing the pins, also I have the same board and cannot flash anything, can I get the link fot the original rom, thanks.
And the 2 pins to short:
ath156
???????Anyone tried this ROM?
https://4pda.ru/forum/index.php?show...entry104930486
unfortunately v4 won't install for me only v3.7 below does
https://4pda.ru/forum/index.php?show...entry101381491
any idea why? Its a very good ATV ROM.
anyone tested it.Last edited by minonano; 29 April 2021, 03:00.
anyone tested it.
There are currently 3249 users online. 0 members and 3249 guests.
