H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by chenrp View PostAnd? I’m still having issues with black screen.
Did you try Smart Youtube?
Sorry but if you still have problems you have to find the reason by yourself.Good luck.
Originally posted by carlero View PostHi guys, I'm a bit disconnected from the topic. is there any new rom? I am in the GT king I think in the first one. are there more versions? or do you know a better rom? I mainly only use it for KODI. Thank you
I use the version that I have uploaded some pages before (as some newer versions had some problems).
Originally posted by gatos814 View Post
I also use a USB 3.0 cable without any problem....
Use the USB 2.0 port of the tv box for flashing!
Also use the latest burning tool with the licence inside!
And also push start in the flash tool and then connect the box!
Good luck!
perfect it is not, remote control sometimes fails and Wi-Fi is not very stable among others
As far as the WiFi is concerned I can not tell you much because I mainly use ethernet. Even when I use wifi the connection is perfect, but the router is at the same room (so this is not a typical case).
Originally posted by ath156 View Post
For me the remote control Never fails and I use 3 different kinds of remotes (the original, an airmouse and a rii mini style remote). Do you use the version I have and I have uploaded here?
What do you mean EXACTLY ?
the wi-fi sometimes appears connected and in reality you are not apart from that it is not always fine, I lose connection when the router is relatively close, with other devices I have no problem
the remote control some buttons lose their function, for example the mouse mode does not work and in the kodi application when you press the list button it goes to mouse mode.
Also if you can identify your tv box hardware (ddr3 or ddr4) and finally give us more details about your problem and when that started!
Regards
Can you tell us what firmware do you use and what is your tv box version of Android ?
Regards
for a few days I have been with the original rum aml_s905x2_9.0_H96Max_X2_mac_wifi_20190920. my box is DDR4 or that buy. the problems are those that I comment I don't know what else to tell you. I think that the Wi-Fi has always given me problems, the control was when I installed the GT king and now with the one I have, they continue. Thanks for your interest
First of all if you are facing issues with the wifi like immersions or things like that with both of the firmwares try to check your power adapter or your tv box with other power adapter!
And about the GT king rom and some of the buttons on your original control you must know that's a common issue with these kind of porting roms!
You must consider of buying an air mouse if you'll choose to stay with this rom or with other similar ones!
There are currently 3444 users online. 0 members and 3444 guests.
