[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Originally posted by Xannytech View PostXTM 2.0 Online here are the links:
XTM X96 Max 3/4Gb v 2.0
XTM X96 Max 2Gb v 2.0
Please about installation refer to post #170it's very important to avoid any problem.
Then use Amlogic Usb Burning 2.1.7.0 please to flash my firmwares.
The Gt1 Mini version will come shortly i hope
I'll update the links in first page just when all the three fws are ready cause for some reason here my post are marked as spamIf you like my works and would you like to offer me a beeror a coffe, or a sign of appreciation :
SEND ME A DONATION
Xannytech, thanks for version 2. I was satisfied with version 1 on my T95Q although Kodi 18.2 wasn't able write to my external hard disk, which still is pretty annoying. I was curious and installed version 2 today.
Unfortunately this version introduces a second issue for me. My old Sony receiver only has spdif inputs. I disabled hdmi and I enabled spdif in the Droid settings, but it seems that multichannel audio isn't available anymore on my T95Q. I also noticed that I can't change the settings in Kodi, to enable/disable passthrough, DD5.1, DTS etc. These setting are not visible anymore.
Any idea if this can be fixed?
The stand out thing I would like added is the ability to delete files on an external HD when I am using Kodi. At the moment I can drop out of Kodi and delete an unwanted video in Total Commander but it is a clumsy solution.
The only ROM that was capable of this was on my Minix box and the ability is very liberating.
I believe the permissions have to be tweaked.
I thought FTMC was responsible in giving me this ability on the Minix ROM but this is not the case as I have installed FTMC on this latest ROM by Xanny and it will not delete files on an external drive.
Maybe only Finless can do this, I dunno, but none other has achieved that that I have tried.
Originally posted by Charlie_Boy View PostThe stand out thing I would like added is the ability to delete files on an external HD when I am using Kodi. At the moment I can drop out of Kodi and delete an unwanted video in Total Commander but it is a clumsy solution.
Originally posted by Charlie_Boy View PostAnyone else having problems logging in and posting? I have to log in around seven times and then get logged out again. Same thing when trying to post a comment.
Originally posted by zoelechat View Post
Did you try if "ExSDCard Access Enabler" Magisk module was doing the job for external HDD as well?
I think everybody has problems with everything here
Any way I can get rid of the originals that don't allow deletion?
Yaaaaay that works. I feel unchained. BUT now I have two of every drive and the second one of each won't allow deletion. So in total I have 4 HDD's connected but I see 8.
Wondering if they could be unmounted maybe, not sure...
Mmmh I don't think so, it's expected that you see each drive "doubled" since module kind of symlink read-only drives to an r/w place.
There must be a way to lose those mounted in /storage/ without losing those in /mnt/media_rw/
I've gone into Setting/System Info/Storage and I see the 8 drives, 4 are mounted to /storage/, but the new 4 are/mnt/media_rw/
Code:umount /storage/BLAH-UID1 umount /storage/BLUB-UID2 etc.
Well you still can try to unmount from terminal and see what happens, but as told I'm not sure of the result
Thanks anyway.
There are currently 1211 users online. 0 members and 1211 guests.
