I have also tried the USB 3 hub on my Minix and may now stay with that because, hey presto, my lag problems seem to be cured.
[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Originally posted by Javenroth View Post
I have also tried the USB 3 hub on my Minix and may now stay with that because, hey presto, my lag problems seem to be cured.Last edited by Charlie_Boy; 07 February 2019, 17:22.
Originally posted by Charlie_Boy View Post
I have tried my Bandridge USB 2 hub and the X96 still only finds 2 drives but mounts only 1 of those 2. My Orico enclosures have the same firmware and on my Minix X8H Plus all HDD's are instantly recognised and mounted. Though as I said this was only after a firmware update on that box.
I was having similar problem long time ago, only 2 out of 4 hard drives in orico was detected by Dune HD Base 3D. This orico was never having problem with PC or laptop, 4 hdd was detected without any problem. The solution was updating the orico firmware. Just give it a try, it wont be longer than 1 minute to flash.
Other possibility is that you have 2 hdd with same signature, eventhough it is like one in a million.
Other than this, I dont have any idea, probably it is true because of the ROM.
Javen
Can you replicate this issue yourself? Another poster said that he had no problems connecting multiple drives.
Originally posted by Xannytech View Post
Yes, with three drives but after more testing i don't know if is a Android issue or a power issue, because it's random. Anyway i stopped this kind of testing because i got to update many project this firmware is one. Though i like to experiment things
SD card
SD card (2)
SD card (3)
SD card (4)
and filesystem root/storage
Udisk0
Udisk1
Udisk2
Udisk3
On the X96 they are listed as:
USB external storage 1
USB external storage 2
Tried a screen grab but on the Finless ROM it captures a solid black picture. So cannot do it.Last edited by Charlie_Boy; 08 February 2019, 18:27.
I have noticed on my Minix and Total Commander the drives are listed as;
SD card
SD card (2)
SD card (3)
SD card (4)
Udisk0
Udisk1
Udisk2
Udisk3
there are ages between your Minix and these devices it's pretty normal things are hugely different.
I am testing my very old UM8 S802 box and it plays huge files from external drives just as well as my Minix X8h Plus and the X96, provided I use a USB 3 hub. The X96 does not lag with a USB 2 hub, so there is a difference.
I am surprised by this because the UM8 is USB 2 and so is the Minix which is also improved. Both boxes have a new lease of life due to the new hub.
The UM8 also mounts multiple external USB HDD's the easiest of all my boxes.
There are currently 1141 users online. 0 members and 1141 guests.
