Sent from my ONEPLUS A6003 using Tapatalk
[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Dear Xannytech, there was a setting on the original T95Q, but I couldnt get it to work either. I used the app Automate to prevent the box from going to sleep, because I lost my ethernet connection comming out of sleepmodus, and I needed to reboot every time to get a new connection. Your Rom got that fixed for me, so thank you for that! I know how to shut down the box, but what I meant was that though the box is shutdown, the led ring around the T95Q Box is still on while shutdown. On the T95Q there is no voice controle standard. Your rom gives me that opportunity so thanks again!
Originally posted by kamerzeekoetje View PostDear Xannytech, there was a setting on the original T95Q,
What i would like to do is to bring all the nice and useful things in one pack...
Now... my firmware works "incidentally" on your device, if you can understand what i mean, i do not own it but because is based on a similar motherboard and i put every driver i know in this rom, it works pretty good. Led stuff etc... cannot be controlled by another firmware meant for another device that uses GPIO drivers in a different manner.
Anyway until now i was working on my ATV firmware, i uploaded it on mega yesterday, whwn i get more free time i'll compose and post a new post for it
Thanks a lot for sharing your experience on my fw.
Xanny
Originally posted by Xannytech View PostOk to me the very nice info is this, but if it's unfunctional it's pretty useless, i'll give look to your original fw, send me a link also in pm, thanks.
Xanny
Be quick before this link is gone!
Originally posted by romcrazy View PostWorks on h96 max x2 box. but wifi and ethernet dont work i guess because the rom doesn't have drivers for my box or license keys. Can someone tell me how to get these?
in original fw they are stored in vendor/etc and in vendor/lib, anyway then i probably need also vendor/etc/init to fix the init script to make the driver works... it's faster to adapt a new vendor partition.
Originally posted by Xannytech View PostYou should know which wifi chip has your device, anyway i inserted so much drivers about wifi in my fw, so i think you device need a firmware based on your original fw.
Incidentally the working port is your own rom, ported with some changes like system wide root different launcher and a non working play store. I found it on 4pda and now using its modules folder to get your rom working.
service hdcp_tx22 /vendor/bin/hdcp_tx22 \
-f /vendor/etc/firmware/firmware.le
class main
disabled
oneshot
This text I found extra in your rom's init.amlogic.rc
If modules copying doesn't work, I will delete this text from init rc to match the working port
## root permission
service daemonsu /vendor/xbin/daemonsu --auto-daemon &
class core
oneshot
seclabel u:r:init:s0
disabled
on propertyersist.daemonsu.enable=true
start daemonsu
## preinstall Apks
service preinstallApks /vendor/bin/preinstall.sh
user root
group root
class main
oneshot
disabled
on property:sys.boot_completed=1
start preinstallApks
# add remote mouse start
service remotecfg12 /vendor/bin/remotecfg -t /vendor/etc/remote-mouse12.tab
class core
oneshot
# add remote mouse end
service remotecfg31 /vendor/bin/remotecfg -t /vendor/etc/remote-mouse31.tab
class main
oneshot
This is the excess text I found in working port's init.amlogic.board.rc as compared to yours. But this doesn't look anything like concerned with wifi. more with system wide root and preinstalling app and mouse control. I dont think I need to make any changes to your init.amlogic.board.rc here. Just the first change should do it (if modules copying doesn't work)
Originally posted by romcrazy View PostThis is the excess text I found in working port's init.amlogic.board.rc as compared to yours. But this doesn't look anything like concerned with wifi. more with system wide root and preinstalling app and mouse control. I dont think I need to make any changes to your init.amlogic.board.rc here. Just the first change should do it (if modules copying doesn't work)
Anyway it's a long discussion and honestly i do not wanna fill my rom thread with cooking lessons, regarding also permissions and tools
gimme a link to your original fw and i'll check if is doable or not.
Normally kernel init regarding wifi drivers are in vendor/etc/init/init.amlogic.wifi.rc, anyway that's the correct way of work dunno what manufacturer did for your device.
Link to original stock firmware --- https://drive.google.com/drive/folde...SFyxixhu7JjNBi
Link to ported hellish mixture ---- https://yadi.sk/d/M2jafH9S8Qup7g
Link to the post about this port ---- https://4pda.ru/forum/index.php?foru...st&query=xtmod
I have gone back to stock till I hear from you
Link to original stock firmware ------ https://drive.google.com/drive/folde...SFyxixhu7JjNBi
Link to wifi working port -------------- https://yadi.sk/d/M2jafH9S8Qup7g
Link to post about hellish mixture - https://4pda.ru/forum/index.php?foru...st&query=xtmod
I replaced files in etc wifi and lib modules and init to stock and flashed new modded img and box went into bootloop. i guess it creates differences in kernel boot.img
Link to post about hellish mixture - https://4pda.ru/forum/index.php?foru...st&query=xtmod(for now)
I do not understand what the user did on PDA if he has skill can propose his firmware, but it's better to read logcats before...
Originally posted by Xannytech View PostOk downloading your fw right now, if it's easy i'll give you a fix, if i had to do the work from scratch i will not(for now)
Thank you I appreciate it, would it be possible if you felt it has to be done from scratch maybe you could point me in the right direction and tell me which component tinkering will i need to focus on? So that I have something to go on for myself and not left in the dark?
The firmware has to be done from scratch, i need 7 hours to adapt my custom to it, but i nedd freetime, so maybe later not now. Sorry.
If you want to work on your firmware before you need the right stuffs to decompiel, and recompiel and so on.
There are currently 1641 users online. 0 members and 1641 guests.
