.gif)
[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Originally posted by adagre View PostHas anyone tried Nova Launcher? With this ROM and the stock ROM I cannot drag and drop the icons. I would really like to use Nova.
I believe it's an issue with the action of "long press" in the firmware, some other launchers also give me a similar issue.
Any thoughts on this?
As I said, the developer of this ROM told me it was a problem with AMLOGIC and Oreo, but this problem has been around forever on all versions of Android. Every solution I found never worked, so I just solved it myself by installing about 40 launches and 40 browsers to see which ones did not have the problem. Sure I had to give up Nova Launcher and Maxthon, but at least I can drag and drop and scroll on websites now.
Originally posted by kolinsb View PostYes, i tried to change port on my PC, but I still have a problem. USB tool recognize X96 mini without any problem. Can you explain me about re-sign the zip file?
Originally posted by Xannytech View PostApps do not follow google android rules so you can get problems in scrolling etc etc, Oreo is much more strict in this sense, this is what i mean and Oreo has more problem with mouse devices, try to click an "ok"... just a little part of it is clickable on MM never got a problem.
Originally posted by Porkie View Post
But apps are developed based on what Google requires for them to run on the system. You cannot just take anything and run it on Android, or any other OS for that matter. The mouse problem may be firmware related for sure, but the problem of not being able to drag and drop icons or scroll in browsers is clearly app related. The problem has been going on forever, and it usually happens on many devices after a new version of Android is released. Its because developers are still making apps the same way, and have not added full compatibility for every single device.i agree, but from Oreo you cannot avoid to follow Google rules.
Originally posted by Javenroth View PostThanx Xannytech,
Tried this ROM for several days. Seems all working well. So stable, and I reconfirmed that Total Commander, ES explorer, Storage in settings and Kodi , all recognized all 4 HDDs in my Orico enclosure, with or without root access.
Javen
Originally posted by Charlie_Boy View Post
I am awaiting delivery of a new Orico USB 3 hub that will hopefully sort out my problems with HDD recognition as my current one is a generic. Then I will test this ROM. I have four Orico enclosures which work perfectly with my Minix X8H Plus and my ancient UM8 but the X96 refuses to see more than 2 drives, it only becomes an issue when I want to watch any 10 bit HEVC files as the older boxes are 8 bit. The annoying part is that the UM8 is the best at recognition and that box and firmware are a lot older than my enclosures, so firmware in the enclosures doesn't look like the problem.
ATV 3 is also good, I installed it in my other box. And no problem so far.
Javen
I have been running this Mod for about a month now and it runs very well thanks for your work.Last edited by [email protected]; 20 February 2019, 02:38.
There are currently 1172 users online. 0 members and 1172 guests.
