[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Thanks for reply. I understand that about re-sign. The file "updater-script" has this content. Which part i need to remove to avoid checking of version? Or I can simply remove whole file from .zip
Code:ui_print(" "); ui_print("*** Install Amlogic firmware update ***"); ui_print(" "); set_progress(0.0); # Confirm we're working on the right device and ROM version ui_print("- Confirming target device..."); show_progress(0.1, 5); mount("ext4", "EMMC", "/dev/block/system", "/system"); ui_print(" Found: " + file_getprop("/system/build.prop", "ro.product.model") + ", " + file_getprop("/system/build.prop", "ro.build.description")); (file_getprop("/system/build.prop", "ro.product.device") == "KM9") || abort("E3004: This update package is intended only for the KM9."); (file_getprop("/system/build.prop", "ro.build.version.sdk") == "27") || abort("E3003: This update package is intended only for Oreo builds (SDK 27)."); unmount("/system"); # Update the system partitions ui_print("- Patching system images unconditionally..."); show_progress(0.7, 90); block_image_update("/dev/block/system", package_extract_file("system.transfer.list"), "system.new.dat", "system.patch.dat") || abort("E1001: Failed to update system image."); block_image_update("/dev/block/vendor", package_extract_file("vendor.transfer.list"), "vendor.new.dat", "vendor.patch.dat") || abort("E1001: Failed to update vendor image."); block_image_update("/dev/block/odm", package_extract_file("odm.transfer.list"), "odm.new.dat", "odm.patch.dat") || abort("E1001: Failed to update ODM image."); # Update the boot and recovery partitions ui_print("- Installing new kernel and recovery..."); show_progress(0.1, 5); package_extract_file("boot.img", "/dev/block/boot"); package_extract_file("recovery.img", "/dev/block/recovery"); # Update the bootloader partition ui_print("- Installing new logo, device tree and bootloader..."); show_progress(0.1, 5); package_extract_file("logo.img", "/dev/block/logo"); write_dtb_image(package_extract_file("dtb.img")); write_bootloader_image(package_extract_file("bootloader.img")); ui_print(" "); ui_print("Installation successful."); ui_print(" "); set_progress(1.0);
Originally posted by kolinsb View PostThanks for reply. I understand that about re-sign. The file "updater-script" has this content. Which part i need to remove to avoid checking of version? Or I can simply remove whole file from .zip
Code:# Confirm we're working on the right device and ROM version ui_print("- Confirming target device..."); show_progress(0.1, 5); mount("ext4", "EMMC", "/dev/block/system", "/system"); ui_print(" Found: " + file_getprop("/system/build.prop", "ro.product.model") + ", " + file_getprop("/system/build.prop", "ro.build.description")); (file_getprop("/system/build.prop", "ro.product.device") == "KM9") || abort("E3004: This update package is intended only for the KM9."); (file_getprop("/system/build.prop", "ro.build.version.sdk") == "27") || abort("E3003: This update package is intended only for Oreo builds (SDK 27)."); unmount("/system");
Thanks for reply. I removed just this two lines:
Code:(file_getprop("/system/build.prop", "ro.product.device") == "KM9") || abort("E3004: This update package is intended only for the KM9.");
usb burning tool still don't see devicethat's realy weird
edit: I made. I downloaded original ota from 4pda.ru forum (before i used ota i downloaded here, its made by Magendanz i think). Thanks a lot. I hope you will make fw for this model toothis box is nice piece of hardware but software is shit
No! I have KN9 with google voice RC. Installation of this firmware was ok, without any errors during installation (I used USB burning tool), but after installation I got this:
1. Bluetooth has stoped. I couldn't to enable it anymore
2. I couldn't to enable WiFi too
3. I couldn't to use remote controller (I could to use remote which I got with Sunvell H3 box but that's not solution)
4. Front led had red light constantly
Summary: KN9 in my case, with this mod is complety unusable
Sent from my POCOPHONE F1 using Tapatalk
Originally posted by kolinsb View PostNo! I have KN9 with google voice RC. Installation of this firmware was ok, without any errors during installation (I used USB burning tool), but after installation I got this:
Originally posted by Rustdroid View PostInstalled the x96max 4GB version on the mecool KM9 and everything is working okay so far wifi and bluetooth work, Remote works via bluetooth. Runs faster than stock. Same problem with mouse.
Mecool Km9 for the steps to install suggestion or comments?
Great work Xannytech
TestedX96 Max 4/32 & 4/64 Version 1.0 Betaon my T95Q
Fast flash with no issues 3.35min to finish burn
35 sec boot time to home screen
wifi and Bluetooth both work
Good to see top and bottom bars
So far everything seems to work very well on the T95QPlease consider making a Donation to freakTab
on my T95Q
Many other fixes are coming... i found many things to be corrected in the next release.
P.S.
could someone sticky my rom post?
Originally posted by Xannytech View Post
could you share your working ota zip here? could be useful for users that get problems like yourself.
I think that MEGA links from that post are down, and I re-uploaded file. Here is my link for KM9-ota-V0828.20181122 download
Hi. I downloaded it from here: http://4pda.ru/forum/index.php?showtopic=930374&st=560
https://mega.nz/#!MXgC2aYI!r0qvOfkcj...K4lqOWaZeNlkMA
There are currently 2958 users online. 1 members and 2957 guests.
