[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Originally posted by Xannytech View Post
Originally posted by romcrazy View Post
Sir I am using amlogic customization tool but it doesnt seem to work for me, even if i make a tiny change like adding a file, the repacked firmware doesnt boot, I understand you are busy and I would not want you to spend your energy for a device which probably you dont own, that is why i was merely hoping if you could just tell me which tool should i use and which component concerning "effective differences around connectivity" should i focus on? Because if I manage to whip something up which works for me, with due credits to you, I could just use that newfound knowledge to port your future roms and other people's roms too without bothering them. Then you can post newly built rom here maybe in new thread for other h96 max x2 owners to benefit. Please?
You need knowledge and tools, tools available on linux,you have to use terminal commands, not just clicks, or wait an easyest tool from here, i helped him for the new version 6 that is coming out soon.
Yes you're right i do not own your device and too many project open... so i have to focus jsut on few or it's a mess. :P
Amlogic tool does not work from Android Marshmallow, i can't and i won't, as i stated before, make this thread a cooking class.
That precisely is the tool I have used and failed that you linked. Anyways, I can wait it out till a developer actually buys my device and builds something for it. Thank you for your time and help, I appreciate it. I guess I should focus on learning enough linux the way android is going, linux seems to be the future. Thanks again sir.
hey bro how are u. i have ordered x96 max 64 gb and im still waiting for it to recieve . just want to know any advice from before i start using it .shall i make the ota updates immediately ? i think i want to use it for a while with stock rom cus im afraid ill brick it if i flash it. i just want to use it for streaming and sport using kodi builds and other apks for live streaming.
Originally posted by bishopx26 View Posthey bro how are u. i have ordered x96 max 64 gb and im still waiting for it to recieve . just want to know any advice from before i start using it .shall i make the ota updates immediately ? i think i want to use it for a while with stock rom cus im afraid ill brick it if i flash it. i just want to use it for streaming and sport using kodi builds and other apks for live streaming.
Update XTMOD Android TV 3
I'm in the process of completing the FINAL version i hope the third of my Android tv firmwares because it's a huge step forward .
So far what i've done:
- Fixed Android Tv remote App;
- Fixed Chromecast;
- Fixed Webview little bug;
- Removed Chrome in favor of Firefox for Android TV;
- Updated many Android Tv apps;
- Fixed AOSP keyboard disappearing on some languages;
- Generic.kl reverted to stock due some user complaining (i use an airmouse);
- Huge changing in framework...i used some dirty tricks... but it's better;
- Many things i forgot to note in the process.Last edited by Xannytech; 06 February 2019, 19:32.
- Fixed Chromecast;
Hi Charlie boy,
I got a lot of tv boxes like x96, x96 mini, X96 s905w, tanix, x96max etc. I flahed those with various ROM, and none of those has a problem with the number of HDD. I got all 4 HDDs, 2TB each, loaded to 4 bays orico enclosure, and connect one usb cable to tv box and everything is just work perfectly. If you have a problem, maybe you need to check the firmware of your HDD enclosure, or try different usb hub.
Javen
Обновление XTMOD Android TV 3
Я заканчиваю финальную версию, надеюсь, третья прошивка для Android TV, потому что это огромный шаг вперед.
Пока что я сделал:
- Исправлено удаленное приложение Android Tv;
- исправлен Chromecast;
- исправлена небольшая ошибка в Webview;
- Удален Chrome в пользу Firefox для Android TV;
- Обновлены многие приложения Android Tv;
- Исправлено исчезновение клавиатуры AOSP на некоторых языках;
- Generic.kl восстановлен на складе из-за некоторых жалоб пользователей (я использую аэромус);
- Огромное изменение в фреймворке ... я использовал несколько грязных трюков ... но это лучше;
- Многие вещи я забыл отметить в процессе.
Hello! when can we try this ROM
Javen
There are currently 2557 users online. 0 members and 2557 guests.
