[ROM]XTMOD for u211 devices (X96Max, GT1Mini & some others), Magisk rooted and many others fixes and mod.
Originally posted by Muckluck View PostLooks like very nice work on your part. Tried it on H96 Max x2 but can't get wifi to work. Hoping you can rectify that. I'd like to see if it improves this piece of crap box.
Open in chrome browser and translate. Its Xtmod rom by xannytech, modded by sergej to include wifi.
That thread is for our h96 max x2 box and has some very nice roms taken from freaktab and modded to add wifi bt capabilities. No our box is not crap, My personal daily driver:
Really beautiful rom, with one problem, its launcher is in russian, but that is rectified by finding lighthome launcher apk online and replacing in system and giving correct permissions. You cant factory reset though afterwards because you replaced a system file. I have not felt the need to reset or change anything after this. Droid tv settings are also in russian, but that apk can be replaced too (if you and paranoid)
Hello everyone
First of all, i'd like to thank Xannytech for this great Firmware release.
I own a TX5 Max and i tried this ROM on it
It runs really smooth (it was nice to see the CPU is running at 1.9GHz
Has the GPU also been overclocked? If so, to what speed?
This Box has not the same WIFI chip as the GT1 Mini ( TX5 Max : fn-link 6222B-SRB wich is a RTL8822 ; GT1 Mini : AP6255 ; the X96Max i don't really know wich WIFI chip it has )
But the WIFI is working very good
I can't say the same about Bluetooth, that doesn't work.
Geekbench always aborts at the end of the test and does not report the scores.
I've tested several launchers, only one i can drag and drop is ADW launcher 2
Browsers that also suport long click ...only Samsung browser XD (but i can live with that)
I'll keep doing some tests and be reporting here every now and then.
Dumb question... : Is it possible to add drivers in a ROM for several diferent WIFI chips?
Thanks in advance
Definitely nice work! My H96 Max x2 accepted it no problem. Works better than my stock firmware for sure. My box is still sluggish at best. I still can't play Real Racing 3. Audio plays fine but video doesn't keep up. I've now tried different versions of firmware and none seem to rectify this. I truly believe I have a bad unit. Sad that the seller won't respond and now have left a complaint with Wechip and hoping they will come up with a resolution for me. Will keep you posted!
Originally posted by Muckluck View PostDefinitely nice work! My H96 Max x2 accepted it no problem. Works better than my stock firmware for sure. My box is still sluggish at best. I still can't play Real Racing 3. Audio plays fine but video doesn't keep up. I've now tried different versions of firmware and none seem to rectify this. I truly believe I have a bad unit. Sad that the seller won't respond and now have left a complaint with Wechip and hoping they will come up with a resolution for me. Will keep you posted!
It's not the game....I have 3 other boxes. All are MXQ Pro Max with RK3328 processors 4gig of DDR3 and 32gig memory, The games play fine on them. Given the specs of the H96 Max x2 it should outperform the MXQ's but falls far short. I've contacted the seller but am not getting any response from them. I've also sent a message to Wechip to see if they would come good on the box but it's only been a day so I'll just have t wait. I've already replaced the unit with an MXQ Pro Max and for now am quite happy with them. I am not that familiar with the android boxes and have only flashed the H96 a few times. I don't have any expertise and only learn from this forum .Hope you find a good controller. Got mine at Walmart/ EVO something. Cheap ....less than $20 with Bluetooth. it pairs well and works well. Not recognized by all games though.
Hello xanny,
my x96 max just arrived but i dont get any video signal from hdmi and i dont have proper analog video cable so i dont know if the device boot properly, i see boot message on led display than the time and hd letters lit, i tried to reset the device via reset switch into the av port still no video, i have a long usb 2 a to a male cable and i couldnt get it detected by the usb burning tool.
So here is the real question can i burn your rom thru sd card if yes how.
Thanks in advance
Thanks in advanceprobably or it's a usb cable issue or a driver issue in your case but i can't be sure.
Thanks in advance
There are currently 1598 users online. 0 members and 1598 guests.
