Hi folks i'm here to present you one of my last public works.
If you're used to my roms should be very familiar
It's based on a mix of firmwares and i took the best from every official firmwares published, most of the vendor partition is compiled just for this fw.
I do not use stupid old fashioned deprecated build.prop lines and just put a fancy Rom name, it's a real Modded Rom.
- Has Magisk root yet installed, but please do not update to magisk 18.0 or root will not work anymore;
- Has selinux in permissive mode;
- Is deodexed;
- Tweaked and fixed;
- Fixed stupid keyboard bug;
- Added support for many gamepad and accessories;
- Has the newest 0zm0sys busybox installed;
- Kodi & SPMC optimized;
- Square Home 3 Launcher installed;
- Nano gapps installed;
- Top Bar an Navibar enabled;
- Many things i do not remember,
Flash it with Amlogic Usb Burning Tools 2.1.6.8: load the fw, then, after the file check is completed click start, plug the usb male to male cable in the blu usb (3.0) and wait for completion.
I'll post also OTA zip files for the stable version of the rom.
Later on i will add TWRP, actually i need testing without it.
I found no bugs so far,
Anyway as usual i'm shortage of time so here are the links :
- X96 Max 4/32 & 4/64 Version 1.0 Beta Reported to work also on T95Q, about Mecool KM9 i'm not really sure.
- X96 Max 2/16 Version 1.0 Beta
- GT1_Mini Version 1.0 Beta
Terminal app does not start;
After some testing by the users i'll post for more device and more updated firmwares and a ATV version, it's just a matter of time and interest by the users
Thanks Xanny
Enjoy!
If you like my works and would you like to offer me a beer
SEND ME A DONATION
