hwaddress ether 9E:89:10:F2:BF:18
Now available Ubuntu, Lubuntu or Xubuntu on the latest MK802IV or T428
Virtual serial port
I'm trying to use this Linux system to communicate with hardware through a virtual serial port, and it seems that the kernel is missing the CDC-ACM driver needed to do this. Any suggestions on how to get the virtual serial port support in the kernel? I'm assuming the kernel has to be rebuilt, but I thought I'd ask.
TV Blinks
Hello i need some help. I installed the ubuntu 12.04 from the image provided, but the screen is flickering all the time. My device is BT919 with AP6210 wifi and i tried both 720p and 1080p kernels. Can someone help me? Thanks in advance. Also on the 720p kernel when i boot into unity it says "couldn't restore the previous screen settings" or something like that. Also i don't have wifi at all, the wifi chip (AP6210) is not recognizableLast edited by convict; 13 May 2014, 07:07.
HI,
I have flashed the Xubuntu on my MK809III (which I believe is a MK802IV compatible device), the flash process went with no problem but after booting it stops when trying to mount /dev/mtdblock2 on /mnt with following message:
ALERT! /dev/mtdblock2 does not exist. Dropping to a shell!
what I did wrong? I have for sure unziped the system image and I did the flashing two times, both with same result. can anybody help me?
Originally posted by convict View PostHello i need some help. I installed the ubuntu 12.04 from the image provided, but the screen is flickering all the time. My device is BT919 with AP6210 wifi and i tried both 720p and 1080p kernels. Can someone help me? Thanks in advance. Also on the 720p kernel when i boot into unity it says "couldn't restore the previous screen settings" or something like that. Also i don't have wifi at all, the wifi chip (AP6210) is not recognizable
Originally posted by linuxium View PostDoes the BT919 have a true RK3188 CPU or a RK3188T CPU? I've heard of flickering issues with the RK3188T but I haven't pursued it as I don't have a RK3188T device although its on my KIV list.
Aside the flickering, on ubuntu I have no wifi either even thiugh my wifi chip is ap6210
Originally posted by Znet View Postsomeone has a minix x7 with linuxium kernel and eth0 works?
Can someone send me a .ko for this kernel.
There are currently 2047 users online. 2 members and 2045 guests.
