v1.2 Features:
Full Root
Debloat
Pipo Launcher included
Google Play Store fixes, to all for more compatible apps
Reduced System.img file size with ext4 file system
2, 4, 6, 8, 10 or 12gb user app space parameter files
Your choice of stock recovery or CWM (Stock Recovery is the default)
Multi-user support (I finally got this to work correctly) You will see a new option called Users in settings.
Some Internet/Wifi tweaks to improve speed and streaming
Some video performance adjustments
A few general performance enhancements
The Petrus Reboot app
Disabled OTA updates
Brand new boot animation from Tattman65
tun.ko, cifs.ko and m4.ko installed
Download:
RileyROM wifi 1.2
RileyROM 3g 1.2
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
