Pipo M6 Pro RileyROM 1.2
    flash
    Originally posted by GPShunter View Post
    Iv'e already flashed it once but it will not allow me to redo it ? i have followed all instructions but my device will not re flash the rom it will recognise my device but when i go to reboot to flash it stops recognising my pipo and i have to reset it using the pinhole on the back of the tablet. I have installed the correct drivers on my pc. I'm at a loss???
    I can only guess what has happened with you. Please double check if your device corresponds to the image. Personally I have updated my Pipo M6 Max Pro 3 times with stock image and 2 times with Riley's image and returned to stock one again with no problem. Hopefully will try new Riley image soon.
    Did you followed sequence of action as it was advised by Pipo? (switch, restore, etc). Did your downloaded image was not corrupt? I had contact also with customer support (Anna from Pipo, see below). But you can turn to only if you have stock image on your device. Please double check all your moves and I hope you will find some incorrect action. See email address of Pipo customer contact below.
    <[email protected]>
      new fw update came by air- v 1.08
      <[email protected]>
      it is interesting, just switched on , sitting in front of router and new fw 1.08 was pushed on- by size about 5mb only. It is installed, but I see nothing new.
        I have completed all the steps upto flashing the rom Rockchip batch tool is loaded with new fw and when i plug in my pipo the first light #1 turns pink then i press switch and i get "switch done success <1> fail<1> and then i need to restart my tablet once i unplug it from the pc ? And the cycle goes on ???
          flash
          I. ave completed all the steps upto flashing the rom Rockchip batch tool is loaded with new fw and when i plug in my pipo the first light #1 turns pink then i press switch and i get "switch done success <1> fail<1> and then i need to restart my tablet once i unplug it from the pc ? And the cycle goes on ???
          Press at once volume+ and Power for awhile.
            OK done that and got the dead android with a red triangle and rockchip doesn't recognise my device, restart my pipo and it recognises my device but light #1 stays pink if i press upgrade i get "switch done success 1 fail 0
            If i press restore i get the same message nearly, if i [ress switch it switches off my tablet???
            Oh and the gps test finds no satellites ?
              I think i may have to wait for Sir Riley of ROMshire to release a new rom for this tablet.
                flash
                OK done that andinstrucyioad android with a red triangle and rockchip doesn't recognise my device, restart my pipo and it recognises my device but light #1 stays pink if i press upgrade i get "switch done success 1 fail 0
                So you have followed all the instruction re upgrade from pipo page?
                  flash
                  Somebody moe advanced could advice better, but 2 options else i see
                  1.try return to factory settings
                  2.try rileys rom.
                    Sometimes it happens you should "switch" to enter in flash mode, have you tried?
                    Inviato dal mio M6pro con Tapatalk 2
                      Hey, ya'll,
                      I'm finally getting to work on this next new ROM. I should have it ready to test tonight.
                      Stay tuned!!!!
                      Randy
                        Hey, ya'll,
                        Stay tuned!!!!
                        :thumbup:
                          Hi, Randy and everyone
                          Thanks for Randy's great work and I got a question about M6 pro 3G.
                          Is there any possible to add a function (or app) in the ROM for M6 pro 3G to make a phone call after flashing new ROM?
                            Well, I was trying some new things and got side tracked. Sorry for the delay. I want this to work before releasing it.
                            Randy
                            Randy
                              Randy
                              Lord Randy of Rileyrom hamptonshire, we look forward to your next release.
                              The ability to make phone calls would be marvellous.
                                That is for those who have the 3G version.
                                I'm looking forward for the new rom and in the future for the multi windows version.
                                Anyhow : CUDOS to Randy for all of his magnificant work !
