Pipo M6 Pro RileyROM 1.2
Riley, thank you for all your work. I installed your Rom mainly because my tablet was getting stuck in standby(blackscreen) and I had to reset often, also i had bootloops from time to time. So far no issues. The tablet is more fluent (also went from 18000 to about 18400 in antutu). And the main improvement is wifi performance on longer distance. It was really average and unstable, now it performs the same as my nexus 7.
Re: Pipo M6 Pro RileyROM 1.2
I'm trying to figure out if the freezing issues are from hardware...the stock firmware...or something I did.
I posted a question last night on the Pipo forum about these freezing issues....and they referred me to ME!!!!!!!!!!!Randy
Originally posted by rrileypm View PostI'm trying to figure out if the freezing issues are from hardware...the stock firmware...or something I did.
What does it mean? I don't understand the meaning of 'they referred me to ME' Sorry, but English is not my first language...if you appreciate my efforts this is the link for any donation:
I guess they didn't realize I'm the RileyROM guy...they suggested I contact the RileyROM guy!!!!!Randy
Stupid aswer by them...if you appreciate my efforts this is the link for any donation:
I get an occasional freeze on my M7 Pro...but not on the scale some have reported here.Randy
Originally posted by rrileypm View PostThis ROM is based on the Pipo firmware test release dated 9/28/2013.
v1.2 Features:
Full Root
Debloat
Pipo Launcher included
Google Play Store fixes, to all for more compatible apps
Reduced System.img file size with ext4 file system
2, 4, 6, 8, 10 or 12gb user app space parameter files
Your choice of stock recovery or CWM (Stock Recovery is the default)
Multi-user support (I finally got this to work correctly) You will see a new option called Users in settings.
Some Internet/Wifi tweaks to improve speed and streaming
Some video performance adjustments
A few general performance enhancements
The Petrus Reboot app
Disabled OTA updates
Brand new boot animation from Tattman65
tun.ko, cifs.ko and m4.ko installed
Download:
RileyROM wifi 1.2
RileyROM 3g 1.2
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
Is there an easy way to activate the multi-user capabilty and how to modify the number of users ?
because on the official ROM i do not find the item user in parameters (under applications)
Thanks for your help
Laurent
I have maximum users set to 3 in the build.prop.
You also need to delete the provision.apk in system/app for it to work right.
RandyRandy
Originally posted by rrileypm View PostI have maximum users set to 3 in the build.prop.
Randy
what is the provision.apk exctly needed for?
Is it only for activating certificates? or we loose other functions deleting it?
Thanks for the answer but for your great job most of all!!Last edited by claro966; 09 October 2013, 23:16.
Hi Randy,
Any chance you could somehow share a link to the original latest Pipo share? I tried downloading from Pipo directly but it keeps failing the upgrade after 3 something % download when flashing with RK BatchTool 1.7. I would like to try establish if the freezing is present in the original firmware. The download from Pipo's site takes an absolute age and I'm worried that the last one was perhaps corrupt. Thank you!
The problem is that if it's still there when you try to make a new user account, it tries to run again on first boot and causes problems. It is best to just delete it before you make a new user account.
I'm not sure if the Pipo Launcher will work for the additional user...I haven't tested it.Randy
Just read the first time user's guide in the zip file.
RandyRandy
There are currently 2515 users online. 2 members and 2513 guests.
