Pipo M6 Pro RileyROM 1.2
Originally posted by Pipo2000 View Postok, got it... its the bottom bar whose responsable for the reduced resolution, both in portrait or landscape.
I need the landscape numbers.Randy
In reality the full resolution of the m6 pro is exactly the same of the iPad 3-4: 2048 x 1536.
They share exactly the same panel. Verified personally.if you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.2
There is a method to the madness. It seems that the advertised specs are a generality to make it look good in print. However I do need the exact measurements in order to make the boot screens work correctly. Too small is OK...but too big causes a black screen on boot.
I have to make some adjustments based on those readings.
Sent from my M7pro using TapatalkRandy
Trying to flash Riley Rom 1.2
Originally posted by rrileypm View PostThere is a method to the madness. It seems that the advertised specs are a generality to make it look good in print. However I do need the exact measurements in order to make the boot screens work correctly. Too small is OK...but too big causes a black screen on boot.
I'm trying to flash your Rom but there is no "RKAndroidTool.exe" in the RileyRom folder as per instructions. What am I missing please?
The flash tool is in the root folder of the kit. If you need an alternate tool to switch to flash mode, the rkbatchtool is in the alternate tool folder.
Originally posted by rrileypm View PostThe flash tool is in the root folder of the kit. If you need an alternate tool to switch to flash mode, the rkbatchtool is in the alternate tool folder.
Commencing flashing!!!!
Edit: Flash failed miserably... Got "MSC can't do erase IDB" message
Just follow the tips in the First Time User's Guide.
There are currently 2022 users online. 1 members and 2021 guests.
