Pipo M6 Pro RileyROM 1.2
    Can someone run an Antutu score with this new test ROM and tell me what the actual screen resolution is?
    I need to tell Tattman65 what size to make the boot animation.
    Randy
      Is it possible to have a CWM flashable firmware so we won't need to wipe everything everytime? It would be even more easy to test firmware(s).
      Tnx for your work.
        AW: Pipo M6 Pro RileyROM 1.2
        There is a folder clockwork template and a file rominstall.zip inside. Read the readme and you will know what to do.
        I did install every update that way and it works perfectly. Just be informed that the parameter remain the same every time.
        So once you decided to have a 6gb f.ex. it will not be changeable via cwm install.
          Can somebody confirm the deep sleep mode with FW1.3? That would be great!
          I have only "half" root access to my stock rom and would like to save my apps with titanium. Is there any way to geet full root, before flashing rileys work?
          Greetings from Hamburg,
          Chris
            Originally posted by picaye View Post
            i use the root tools from here http://www.rockchip.nl/downloads/
            Hi there,
            You can root your stock fw with the above tools.
              Originally posted by CiR3 View Post
              Hi there,
              Thanks! i have done with "TPSparkyRoot" now I have full root.
              Just backing up my apps with Titanium, so I can restore them after flashing riley 1.X.
              Is it necessary to calibrate the battery after flashing?
              Anyone who tested riley 1.3?
              Does it work?
                features
                Dual UI: Tablet and Phone. Default is TabletUI but this can be changed by editing the line ro.rk.systembar.tabletUI in /system/build.prop (change it to false for PhoneUI and reboot).
                - Google Play Store fixes: it should find more applications (e.g Google Earth).
                - Zip-aligned
                phone interface?
                  battery
                  Does it work?
                  my pipo m6 max pro with wifi only enabled with last stock fw battery drains rather fast...
                  Any remarks about longer battery life?
                    you running the test ROM? Do you have lags with it?
                    Now i am running 1.2! Forgot to say tthat i am using also the HD resolution. Is the m6 really too slow for it?
                    Sorry, i cant test the new Rom because i am not at home in this week. I hope i can test it on sunday!
                      hd mode
                      yea hd made system slower when i bought it -before 1st fw change -and battery drained faster
                        Hi Randy
                        I opened the stock bootanimation from PiPO ROM and the .png files inside are exactly 2048 x 1536 of resolution.
                        Hoping could help
                          Are you running the test ROM? Do you have lags with it?
                          I flashed the 1.3 test ROM but it does not boot
                          start with the logo.bin screen and then it get all black (still ON but black) and the appears only a quarter of screen ....
                          Tryed also with a restart and a hard reset but still the same result!
                            On Post #155 I added a link to a newer version that does boot. Try it.
                            Randy
                            Randy
                              Battery test
                              Last night I made a battery test with stock FW 20131015:
                              10 hours and 20minutes with screen off, wifi on and no activities drains battery from 100% to 85%, so 15%
                              Can someone make a similar test with riley 1.X?
                                M6 Pro Screen Rez
                                The 9.7" screen is 2048x1536
                                Sam
                                Sam
                                PiPo M6 Max/Pro
                                PiPo M9 Pro
