[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
    Hi there guys and girls, one more rom/fw for you all!
    And many thks to trebor for be my beta tester
    This rom is as "TRUE" to AndroidTV as possible, no other mambo jambo shit... like i said as true ATV as possible!
    Build from Latest source.
    Debug Build
    NO RTL CHIPS SUPPORTED, it might work on some but not all... BT no RTL chips work at all.
    Overvations:
    • After the Box boots and it shows the language screen pls let it idle there for 1 or 2 min so background tasks finish.
    • When you finish setup and you are on launcher screen, let it also idle there for 5 min when playstore suggestions appears on main screen of launcher go to play store and manual update the apps.
    • Both above are only done 1 time on first boot after flash.
    • First time you put the Box to sleep it will take long time to actually sleep, dont worry is normal it will eventually sleep, this only happens 1 time after a power cycle after that it will go to sleep fine and "fast".
    Changelog *Fix*:
    • Fixed TWRP...
    • Fixed GT1 mini remote
    • Organised remotes
    • Added 3 more settings to build.prop
    Changelog:
    • Build from latest AML Pie SDK
    • ATV Build Path used.
    • Fixed a few issues present in latest sdk.
    • TWRP
    • NO ROOT (i do not root my roms sorry but you can have su in shell since is a debug build )
    • Small change in kernel.
    • Fixed CEC.
    • Fixed force_land.
    • Reduce the time the mouse icon stays on screen.
    • Removed some -Null- pop ups
    • Some fixes to settings provider.
    • Modified DroidSettings.
    • Modified TVSettings, added ?Display? to menu to call DroidSettings
    • Removed White settings just like true ATV.
    • Double click home brings up Recent Apps in Grid View.
    • Long press home calls all apps
    • Long press Mic Key in remote calls assistant ( only tested in Beelink King Remote )
    • Added many KL,s for many keyboards.
    • Added Beelink King remote support. ( more to be added in the future )
    • Added Provision.
    • Noise filter set to 0, you can edit build.prop and set the one you want!
    • Density set to 320dpi as true ATV.
    • Added some apps. ( not many since i dont like to add to much crap in my roms )
    • Compilation done with optimizations.
    • Changed system and vendor partitions size.
    • Optimized lots of stuff.
    • Custom Gapps ATV.
    • Some small fixes to systemui.
    • Fixed Vulkan support.
    • Removed 1. boot pair remote page.
    • Other small stuff and cleanups.
    Bugs:
    • Of course there is bugs? there always be bugs?
    • Googlecast will not work ok, nothing i can do to fix it since it need certification.
    • Netflix for AndroidTV will not work at all, so use regular netflix already present in the rom.
    Want to buy me a beer?
    Download:
    Install instructions:
    • Use usb burning tool 2.1.7.3 to burn the IMG.
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Can I Use This Rom For Km9 Pro Classic?
      Yes it "should" work with that box, just not sure about remote...
      But from what i got, that box already comes with true android tv so i dont see the point in using this rom, unless it because its a newer build of the sdk!
        Tested Box X96Max?
          Only on Beelink and Khadas give it a go lets know
            Tested on beelink mini, tx5 max, s95, my work box!
              Is it usable t95q
                superceleron ,
                I noticed that you included our afrd in your firmware. But it does not work without root access.
                So, you have a root in the firmware...
                  Originally posted by Sasvlad View Post
                  superceleron ,
                  yes i know, i only included it just in case anyone wants it, its already installed...
                  About root, well they just need to wait for magisk to get fixed or add support to aml android 9.
                    there is no TWRP in your firmware, correct the description, please...
                      Ups LOLOLOL i forgot to add it... LOL i wil fix it in a bit
                      thks for reporting it
                        hmm are you sure? i just tested the img here and its there i even edit it again the img to be sure and its there.
                          Hi, first of all thank you for this rom, it's fantastic, everything seems to be working fine
                          I have a couple of questions
                          The dpi is a little high, it can be changed, right?
                          The power key doesn't work, Is there a way to fix that?
                          Device: Beelink GT1 Mini 95X2
                            Sasvlad , ok i found the issue why the img as the twrp and you guys wont see it... im fixing it and it will be there in next build in a 2h.. i think.. when i get out of work...
                            Yes DPI can be changed in build.prop in vendor partition.
                            hmm weird i thought i added GT1 mini remote, maybei dint... i will add it in fixed build in a few hours!
                              Hope u can include x96max remote too.. thanks
