[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
Originally posted by superceleron View PostYes it "should" work with that box, just not sure about remote...
But from what i got, that box already comes with true android tv so i dont see the point in using this rom, unless it because its a newer build of the sdk!
Originally posted by Maki_SM View PostThx you man . afrd work with all app's . plex , youtube , kodi
About remote , this one : https://www.aliexpress.com/item/3284...27424c4dtUHuPK
Even with stock rom , your first 8.1 ATV s905x2 rom and many others rom work without problem
Can anyone please confirm if google assistant work ?
to run afrd you have to be root? And if so, how to do with Android 9.0? Thanks, that's the only thing that prevents me from installing this rom
dont use filebrowser(is broken and im going to remove it in next build), use totalcommander to install apks (don't forget to give proper permissions when asked, it should auto open side settings already in permissions)
EDIT: I resolved, I had to go to the application settings and allow storage to the installer. Thank you
Sorry for my English I translate from French ...Last edited by alessa; 20 October 2019, 17:48.
Here I have everything set as it should and I encounter two bug. 1.The indicator stays on in off mode and goes out in on mode.
2. (more annoying bug!)
The sleep mode is not a true sleep mode as on your previous rom:
As always i like to give thanks my beta tester trebor , and also Beelink and gearbest for the hw to test on! I know i have been very quiet this days ( weeks, months ), to explain a bit why, i now work for a company that does android boxes ( not for public use for telecoms/isp's etc.. ) well cant call it android boxes since...
but thank you for your work
ok thks nice to know!
Here I have everything set as it should and I encounter two bug. 1.The indicator stays on in off mode and goes out in on mode. 2. (more annoying bug!)
Originally posted by alessa View Post
Salut, aurait tu une r?ponse a cela? Et surtout, serait il possible d'avoir un vrai sleep mode ?
But yes i got the 1? time, i know about the 1. one and is not really a bug, the 2. one i dont know what you mean here is real sleep, did you read what i wrote in 1. page(Observations, last line)?
There are currently 2220 users online. 1 members and 2219 guests.
