On TX5 Max wifi and remote not working. I can repair remote control but I don't know how I can add wifi driver from original firmware. It is possible? Thanks
[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
Originally posted by superceleron View PostGuys, you need to read the title... it says generic.. i cant support all possible functions of all boxes out there, or it said in title a specific box...
Yes the led in GT1 mini is inverted, i will change it in a future build...
Yes CEC wont turn on the box, i disable it in uboot because of some bugs in not 100% compliant TV's (or bad FW on them).., that TV's with issues wont let the box go to sleep!
I will think if i enable CEC again or not.
I just make a feedback.
CEC turn on the box works great, the problem is the box won't turn on TV.
The official CEC is almost unable to use , so your firmware is better than official.
Appreciate for your efforts again.
Originally posted by Maki_SM View PostThx man .Tested on X96Max , just to report no display and remote ( i don't care ) , very snappy , you said that is not rooted but afrd work perfect
Only bad side for me is that Google Assistant not working , with press on remote open Google Assistant but no response
EDIT: forget i forgot in ATV long press home is used to open all apps in launcher.Last edited by superceleron; 05 October 2019, 19:54.
Thx you man . afrd work with all app's . plex , youtube , kodi
About remote , this one : https://www.aliexpress.com/item/3284...27424c4dtUHuPK
Even with stock rom , your first 8.1 ATV s905x2 rom and many others rom work without problem
Can anyone please confirm if google assistant work ?
Originally posted by jcarlos1993 View PostDoes anyone have problems installing APKs files? The package installer close when I trying to install a APK
Originally posted by kzimmer View PostDoes not get past Boot Image on H96 Max X2 S905X2 4GB/64GB after flashing from SD Card. No option to flash via USB Cable as PC will not recognize the box.
Now if you want to go back to stock fw if your "reset" button is not working since this is totally possible since i made the uboot to be generic to all reference boxes if the box get a bit "out" of that design then that might happen... but if you know how to use a TTL debug or if you have one, is just as simple as 1.2.3 to get you box to update mode, since once you have boot img it means uboot is ok and is only not detecting the reset button!
hmm look out since i notice in 64gb boxes ( they all use shity 64gb emmc chips) format of the emmc in 1? boot takes a long time, and i mean long time... in my gt1 mini took 5 min to get past bootlogo to boot animation...
Not trying to hijack here, but I just want to give you a quick rundown of why I have been trying so many ROMs. This box came with Android 9.0. It has working WIFI and Ethernet, but whenever ANY VPN service is used, the Ethernet connection is lost. I've done extensive research on this, and it's a known issue on S905X2 boxes with 9.0.. Any 9.0 ROM I flash successfully has this problem.
Now, to make things more fun, any 8.1 ROM that I flash successfully has no WiFi. Do I need both? No, I suppose not. But it'd sure be nice if these things worked somewhat out of the box!
I had a Bqeel Y4 Max, same specs, same problem.
Sorry for the thread derail.
-Kole
There are currently 5718 users online. 2 members and 5716 guests.
