[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
yes i know, i only included it just in case anyone wants it, its already installed...
About root, well they just need to wait for magisk to get fixed or add support to aml android 9.
I ported to HK1 Play 4/64GB DDR3: https://drive.google.com/file/d/1oPH...ew?usp=sharing
Any way to have fully droid settings?
Originally posted by soldiaz View Post
You know wether there is now?
What you mean by "fully droid settings"? you mean the one with the unneeded stuff that does nothing?
Yes i have it but i disable all stuff that does not work, and yes it does not work at all, the Picture settings i think you mean that one!
I don't think Magisk is still compatible, didn't check recently...
I tried the Xanny ATV 8.1 build and there I have acces to settings menu like the "classic" menu on any Android smartphone. I needed this since it supplies possibility to connect to a specific wifi AP (you need to enter username, password and several other things) which is not accessible through ATV settings (just need to enter WPA code). Droid settings in your Multi ATV9 release does not supply this "classic" settings.
Thanks for response! Well, I think we talking bout different things or - maybe - I used wrong term....
Maybe you can ask Xanny where he got is settings apk and then you can see if you can find a android 9 build of that settings and change it in mine!
Attention: This one does not run on S905x2 HK1 Play 4/64GB DDR3 ! Rom stuck @bootscreen and box gets only recognized while pushing reset button. Originally it gets recognized just by connecting...
Ive ported it: https://forum.freaktab.com/forum/tv-...9-soldiaz-port
superceleron : I wondered that device boots up and everythings working. I just took your system.img and replaced stock one, then repacked....what about the 256hashes ??? :-P
Originally posted by soldiaz View PostAttention: This one does not run on S905x2 HK1 Play 4/64GB DDR3 ! Rom stuck @bootscreen and box gets only recognized while pushing reset button. Originally it gets recognized just by connecting...
My build is secureos, so you will lose use that also!
well, you also lose part of them if you do not use the vendor also the audioserver might crash!
Maybe I try keeping vendor...could be I am lucky and wifi drivers are supported :-P
There are currently 2166 users online. 0 members and 2166 guests.
