For the 2 (true sleep mode) when I choose standby mode as the extinction mode, just press any key on the remote control so that the box lights up, I would like what lights up only when I press the power button. As on your previous rom
[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
Originally posted by alessa View Post
Sorry for the french I forgot to translate.
For the peepz that mentioned not being able to use PC or sdcard after flashing this or anything in that matter, Use the MaskROM mode, which is done by shorting 2 pins on your EMMC chip while plugging in USB to PC.. it bypasses any bootloader locks or mishaps.
I my self wired a momentary switch to mine so I can recover from anyone....
And for the others that mentioned that the x96max and maybe others have a poor EMMC chip., there are only a few manufactures that make emmc chips..
but you could always replace emmc chip if you know what your doing.. if you want faster loading times, grab a 64gb samsung emmc, if you just want a half way better
then what you have emmc chip then buy a 65gb scandisk emmc.. of course you will have to know what your doing when it comes to replacing integrated chips on your board..
you will need a HEAT gun, also a understanding of EMMC chips.. and when you buy the new one, make sure its already balled or else you will have to learn how to reball chips.
and for ones that mentioned support for this and that to the OP of this thread.. Maybe if you all would help the guy out and send or tell him where to get the correct drivers needed for
the support on hardware you are asking for. For example, there are a few sorta unreleased x96Max Android 9 roms around. grab that and extract it, then extract system. and vendor.
then get out the drivers you need out, add them to this ROM.. there are only 3 lines of init code for the x96max LED screen and only 2 or maybe 3 lib files to make front LED work.
you will also need a kernel with the correct leds as well. as for remote, only small changes and one file needed for that// and wifi.. another story..
I have not yet tried this ROM yet, I am a big FAN of ATM and will soon try this rom.. I did make my own ATM Rom under android 8.1 (never released it) but was called PureFusionATM..
I dont dev much anymore as I use too, so I figure im going to give this one a go.. and if anything I feel needs to be changed to work on my x96max device, ill make that change and test it.
and then send a note to OP incase he wants to add it anytime.
I do wanna thank the OP for the time and effort hes put into this ROM, and I love the great support he also adds. True class act....
Tried to flash on HK1 Play 2GB LPDDR4. I receive errors. Anyone can help?
HK1 Play is flashed with x96 MAX 2GB PIE firmware
Code:[20:00:03 003][HUB3-1][Inf]--0-0-1-8 [20:00:03 003][HUB3-1][Err]--CheckFileRunState failed [20:00:03 014][HUB3-1][Err]--[0x10303004]Romcode/Switch status/Identify/Error result [20:00:03 015][HUB3-1][Inf]--Close device handle 0x00000460 [20:00:08 436][Global][War]--User click stop button [20:00:08 441][Global][Inf]--Enable burning 0 [20:00:11 333][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE [20:00:11 334][Global][Inf]--Scan usb device [20:00:11 335][Global][Inf]--Aml scan WorldCup Device [20:00:11 338][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E2D [20:00:11 339][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e2d&subsys_057d1028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:11 339][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&92ffe59&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:11 440][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1b838944&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} xxxxx [20:00:11 441][Global][Inf]--Host: USB-xHCI-kompatibler Hostcontroller [20:00:11 441][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e31&subsys_057d1028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:11 441][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&228378a7&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:11 441][Global][Inf]-------->[Port0]NoDeviceConnected xxxxx [20:00:11 442][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E26 [20:00:11 442][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e26&subsys_057d1028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:11 442][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&4238113&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:11 505][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&21a54a68&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} xxxxx [20:00:11 505][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:11 505][Global][Inf]--Scan USB host controller complete [20:00:11 505][Global][Inf]--Update data center with HubMap [20:00:11 505][Global][Inf]--Update hub3 device data [20:00:11 505][Global][Inf]--Update HUB3-1 [20:00:11 505][HUB3-1][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-2 [20:00:11 505][HUB3-2][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-3 [20:00:11 505][HUB3-3][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-4 [20:00:11 505][HUB3-4][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-5 [20:00:11 505][HUB3-5][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-6 [20:00:11 505][HUB3-6][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-7 [20:00:11 505][HUB3-7][Inf]--Update device path [20:00:11 505][Global][Inf]--Update HUB3-8 [20:00:11 505][HUB3-8][Inf]--Update device path [20:00:11 505][Global][Inf]--Scan end [20:00:15 347][Global][Inf]--User click start button [20:00:15 353][Global][Inf]--SetErase [20:00:15 354][Global][Inf]--Enable burning 1 [20:00:15 355][Global][Inf]--Scan usb device [20:00:15 355][Global][Inf]--Aml scan WorldCup Device [20:00:15 356][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E2D [20:00:15 356][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e2d&subsys_057d1028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:15 356][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&92ffe59&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:15 453][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1b838944&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:15 453][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:15 453][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:15 453][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:15 453][Global][Inf]---------->[Port3]Other device [20:00:15 453][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:15 453][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:15 453][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:15 454][Global][Inf]--Host: USB-xHCI-kompatibler Hostcontroller [20:00:15 454][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e31&subsys_057d1028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:15 454][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&228378a7&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:15 454][Global][Inf]-------->[Port0]NoDeviceConnected xxxxx [20:00:15 455][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E26 [20:00:15 455][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e26&subsys_057d1028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:15 455][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&4238113&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:15 518][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&21a54a68&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:15 518][Global][Inf]---------->[Port0]NoDeviceConnected xxxxx [20:00:15 518][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:15 518][Global][Inf]--Scan USB host controller complete [20:00:15 519][Global][Inf]--Update data center with HubMap [20:00:15 519][Global][Inf]--Update hub3 device data [20:00:15 519][Global][Inf]--Update HUB3-1 [20:00:15 519][HUB3-1][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-2 [20:00:15 519][HUB3-2][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-3 [20:00:15 519][HUB3-3][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-4 [20:00:15 519][HUB3-4][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-5 [20:00:15 519][HUB3-5][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-6 [20:00:15 519][HUB3-6][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-7 [20:00:15 519][HUB3-7][Inf]--Update device path [20:00:15 519][Global][Inf]--Update HUB3-8 [20:00:15 519][HUB3-8][Inf]--Update device path [20:00:15 519][Global][Inf]--Scan end [20:00:24 263][Global][Inf]--Catch DBT_DEVICEARRIVAL [20:00:24 264][Global][Inf]--Scan usb device [20:00:24 264][Global][Inf]--Aml scan WorldCup Device [20:00:24 265][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E2D [20:00:24 265][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e2d&subsys_057d1028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:24 265][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&92ffe59&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:24 366][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1b838944&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:24 366][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:24 366][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:24 366][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:24 366][Global][Inf]---------->[Port3]Other device [20:00:24 366][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:24 366][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:24 366][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:24 367][Global][Inf]--Host: USB-xHCI-kompatibler Hostcontroller [20:00:24 367][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e31&subsys_057d1028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:24 367][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&228378a7&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:24 367][Global][Inf]-------->[Port0]\\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [20:00:24 367][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:24 367][Global][Inf]-------->[Port2]NoDeviceConnected [20:00:24 367][Global][Inf]-------->[Port3]NoDeviceConnected [20:00:24 367][Global][Inf]-------->[Port4]NoDeviceConnected [20:00:24 367][Global][Inf]-------->[Port5]NoDeviceConnected [20:00:24 367][Global][Inf]-------->[Port6]NoDeviceConnected [20:00:24 367][Global][Inf]-------->[Port7]NoDeviceConnected [20:00:24 368][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E26 [20:00:24 368][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e26&subsys_057d1028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:24 368][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&4238113&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:24 432][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&21a54a68&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:24 432][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port3]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port6]NoDeviceConnected [20:00:24 432][Global][Inf]---------->[Port7]NoDeviceConnected [20:00:24 432][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:24 432][Global][Inf]--Scan USB host controller complete [20:00:24 432][Global][Inf]--Update data center with HubMap [20:00:24 432][Global][Inf]--Update hub3 device data [20:00:24 432][Global][Inf]--Update HUB3-1 \\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [20:00:24 432][HUB3-1][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-2 [20:00:24 432][HUB3-2][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-3 [20:00:24 432][HUB3-3][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-4 [20:00:24 432][HUB3-4][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-5 [20:00:24 432][HUB3-5][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-6 [20:00:24 432][HUB3-6][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-7 [20:00:24 432][HUB3-7][Inf]--Update device path [20:00:24 432][Global][Inf]--Update HUB3-8 [20:00:24 432][HUB3-8][Inf]--Update device path [20:00:24 432][Global][Inf]--Scan end [20:00:24 476][Global][Inf]--Burning thread HUB3-1 start [20:00:24 527][HUB3-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000009f8 [20:00:24 578][HUB3-1][Inf]--Connect path=USB-xHCI-kompatibler Hostcontroller/P0/P0 [20:00:24 578][HUB3-1][Inf]--Start burning... [20:00:24 629][HUB3-1][Inf]--------------ERASE BOOTLOADER------------ [20:00:24 730][HUB3-1][Inf]--start SendIdentifyCmd [20:00:24 731][HUB3-1][Inf]--0-7-0-16 [20:00:24 731][HUB3-1][Inf]--Identify status success [20:00:24 731][HUB3-1][Inf]-- low_power [20:00:24 736][HUB3-1][Inf]--Low power command success [20:00:24 739][HUB3-1][Inf]--Read low power success [20:00:24 739][HUB3-1][Inf]--bootloader_is_old [20:00:24 740][HUB3-1][Inf]--Bootloader command success [20:00:24 743][HUB3-1][Inf]--Bootloader is old [20:00:24 743][HUB3-1][Inf]--erase_bootloader [20:00:24 743][HUB3-1][Inf]--Erase command success [20:00:24 751][HUB3-1][Inf]--Read erase status success [20:00:24 751][HUB3-1][Inf]--reset [20:00:24 751][HUB3-1][Inf]--reset command success [20:00:25 758][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE [20:00:25 759][Global][Inf]--Scan usb device [20:00:25 760][Global][Inf]--Aml scan WorldCup Device [20:00:25 764][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E2D [20:00:25 764][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e2d&subsys_057d1028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:25 764][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&92ffe59&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:25 765][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1b838944&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:25 765][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:25 765][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:25 765][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:25 766][Global][Inf]---------->[Port3]Other device [20:00:25 767][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:25 767][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:25 767][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:25 769][Global][Inf]--Host: USB-xHCI-kompatibler Hostcontroller [20:00:25 769][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e31&subsys_057d1028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:25 769][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&228378a7&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:25 770][Global][Inf]-------->[Port0]NoDeviceConnected [20:00:25 770][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:25 770][Global][Inf]-------->[Port2]NoDeviceConnected [20:00:25 770][Global][Inf]-------->[Port3]NoDeviceConnected [20:00:25 771][Global][Inf]-------->[Port4]NoDeviceConnected [20:00:25 771][Global][Inf]-------->[Port5]NoDeviceConnected [20:00:25 771][Global][Inf]-------->[Port6]NoDeviceConnected [20:00:25 771][Global][Inf]-------->[Port7]NoDeviceConnected [20:00:25 774][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E26 [20:00:25 774][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e26&subsys_057d1028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:25 774][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&4238113&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:25 837][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&21a54a68&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:25 837][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port3]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port6]NoDeviceConnected [20:00:25 837][Global][Inf]---------->[Port7]NoDeviceConnected [20:00:25 837][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:25 837][Global][Inf]--Scan USB host controller complete [20:00:25 837][Global][Inf]--Update data center with HubMap [20:00:25 837][Global][Inf]--Update hub3 device data [20:00:25 837][Global][Inf]--Update HUB3-1 [20:00:25 837][HUB3-1][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-2 [20:00:25 837][HUB3-2][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-3 [20:00:25 837][HUB3-3][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-4 [20:00:25 837][HUB3-4][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-5 [20:00:25 837][HUB3-5][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-6 [20:00:25 837][HUB3-6][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-7 [20:00:25 837][HUB3-7][Inf]--Update device path [20:00:25 837][Global][Inf]--Update HUB3-8 [20:00:25 837][HUB3-8][Inf]--Update device path [20:00:25 838][Global][Inf]--Scan end [20:00:25 873][HUB3-1][Inf]--Device is removed [20:00:27 193][Global][Inf]--Catch DBT_DEVICEARRIVAL [20:00:27 195][Global][Inf]--Scan usb device [20:00:27 195][Global][Inf]--Aml scan WorldCup Device [20:00:27 198][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E2D [20:00:27 198][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e2d&subsys_057d1028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:27 199][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&92ffe59&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:27 199][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1b838944&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:27 199][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:27 199][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:27 199][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:27 200][Global][Inf]---------->[Port3]Other device [20:00:27 200][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:27 200][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:27 200][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:27 201][Global][Inf]--Host: USB-xHCI-kompatibler Hostcontroller [20:00:27 201][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e31&subsys_057d1028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:27 201][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&228378a7&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:27 201][Global][Inf]-------->[Port0]\\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [20:00:27 201][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:27 202][Global][Inf]-------->[Port2]NoDeviceConnected [20:00:27 202][Global][Inf]-------->[Port3]NoDeviceConnected [20:00:27 202][Global][Inf]-------->[Port4]NoDeviceConnected [20:00:27 202][Global][Inf]-------->[Port5]NoDeviceConnected [20:00:27 202][Global][Inf]-------->[Port6]NoDeviceConnected [20:00:27 202][Global][Inf]-------->[Port7]NoDeviceConnected [20:00:27 203][Global][Inf]--Host: Intel(R) 7 Series/C216-Chipsatzfamilie - USB-erweiterter Hostcontroller - 1E26 [20:00:27 204][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e26&subsys_057d1028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [20:00:27 204][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&4238113&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:27 249][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&21a54a68&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [20:00:27 249][Global][Inf]---------->[Port0]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port1]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port2]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port3]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port4]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port5]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port6]NoDeviceConnected [20:00:27 249][Global][Inf]---------->[Port7]NoDeviceConnected [20:00:27 249][Global][Inf]-------->[Port1]NoDeviceConnected [20:00:27 249][Global][Inf]--Scan USB host controller complete [20:00:27 249][Global][Inf]--Update data center with HubMap [20:00:27 249][Global][Inf]--Update hub3 device data [20:00:27 249][Global][Inf]--Update HUB3-1 \\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [20:00:27 249][HUB3-1][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-2 [20:00:27 249][HUB3-2][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-3 [20:00:27 249][HUB3-3][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-4 [20:00:27 249][HUB3-4][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-5 [20:00:27 249][HUB3-5][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-6 [20:00:27 249][HUB3-6][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-7 [20:00:27 249][HUB3-7][Inf]--Update device path [20:00:27 249][Global][Inf]--Update HUB3-8 [20:00:27 249][HUB3-8][Inf]--Update device path [20:00:27 249][Global][Inf]--Scan end [20:00:27 296][HUB3-1][Inf]--Device is connected [20:00:27 296][HUB3-1][Inf]--Close device handle 0x000009f8 [20:00:27 347][HUB3-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000814 [20:00:27 398][HUB3-1][Inf]-------------Download DDR.USB----------- [20:00:27 398][HUB3-1][Inf]--3-2-0-0 [20:00:27 398][HUB3-1][Inf]--Control write pll reg1 0xfffa0000:0x000000b1 [20:00:27 899][HUB3-1][Inf]--Control write pll reg1 0xfffa0000:0x00005183 [20:00:28 400][HUB3-1][Inf]--Control write pll reg1 0xfffa0000:0x000000b1 [20:00:28 901][HUB3-1][Inf]--Control write pll reg1 0xfffa0000:0x00005183 [20:00:29 402][HUB3-1][Inf]--Write initial succeed [20:00:29 402][HUB3-1][Inf]--Upload encrypt at 0xff800228 [20:00:29 402][HUB3-1][Inf]--ulValue = 0xe0f83180 [20:00:29 402][HUB3-1][Inf]--Read encrypt value succeed [20:00:29 402][HUB3-1][Inf]--Download DDR.USB,size: 65536! [20:00:29 415][HUB3-1][Inf]--Transfer complete 65536 [20:00:29 415][HUB3-1][Inf]--Run at address 0xfffa0000 [20:00:29 415][HUB3-1][Inf]--RunInRam success [20:00:29 459][HUB3-1][Inf]--0-0-1-8-0-1-0-0 [20:00:29 459][HUB3-1][Inf]--CheckFileRunState return 1-8 [20:00:29 459][HUB3-1][Inf]--0-0-1-8-0-1-0-0 [20:00:29 459][HUB3-1][Inf]--G12 init [20:00:29 459][HUB3-1][Inf]--Get Encrpt ulValue = 0xe0f83180 [20:00:29 461][HUB3-1][Inf]--Have Semaphore [20:00:29 461][HUB3-1][Inf]--Download BL2 [20:00:29 461][HUB3-1]Aml_Libusb_bl2_boot2 start! [20:00:29 464][HUB3-1]sequence= 0, datasize= 16384, fipOffset= 65536 [20:00:29 471][HUB3-1]sequence= 1, datasize= 49152, fipOffset= 393216 [20:00:29 476][HUB3-1]sequence= 2, datasize= 16384, fipOffset= 229376 [20:00:29 484][HUB3-1]sequence= 3, datasize= 49152, fipOffset= 81920 [20:00:29 510][HUB3-1]sequence= 4, datasize= 16384, fipOffset= 65536 [20:00:29 516][HUB3-1]sequence= 5, datasize= 49152, fipOffset= 393216 [20:00:29 521][HUB3-1]sequence= 6, datasize= 16384, fipOffset= 229376 [20:00:29 529][HUB3-1]sequence= 7, datasize= 49152, fipOffset= 180224 [20:00:29 548][HUB3-1]sequence= 8, datasize= 16384, fipOffset= 65536 [20:00:29 554][HUB3-1]sequence= 9, datasize= 49152, fipOffset= 393216 [20:00:29 560][HUB3-1]sequence= 10, datasize= 16384, fipOffset= 229376 [20:00:29 568][HUB3-1]sequence= 11, datasize= 49152, fipOffset= 245760 [20:00:29 626][HUB3-1]sequence= 12, datasize= 16384, fipOffset= 65536 [20:00:29 632][HUB3-1]sequence= 13, datasize= 49152, fipOffset= 393216 [20:00:29 638][HUB3-1]sequence= 14, datasize= 16384, fipOffset= 229376 [20:00:29 646][HUB3-1]sequence= 15, datasize= 49152, fipOffset= 245760 [20:00:29 702][HUB3-1]sequence= 16, datasize= 16384, fipOffset= 65536 [20:00:29 709][HUB3-1]sequence= 17, datasize= 49152, fipOffset= 393216 [20:00:29 715][HUB3-1]sequence= 18, datasize= 16384, fipOffset= 229376 [20:00:29 723][HUB3-1]sequence= 19, datasize= 49152, fipOffset= 442368 [20:00:29 747]BL2 report Error, code= 32 [20:00:29 747][HUB3-1]cmd error, cmdType:43984 [20:00:29 747][HUB3-1]Aml_Libusb_bl2_boot2 end! [20:00:29 747][HUB3-1][Inf]--Release Semaphore [20:00:39 942][HUB3-1][Inf]--Detect Device remove timeout [20:00:39 942][HUB3-1][Inf]--Device is connected [20:00:39 942][HUB3-1][Inf]--Close device handle 0x00000814 [20:00:39 993][HUB3-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&1fbf6c68&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000009f8 [20:00:45 044][HUB3-1][Inf]--0-0-1-8 [20:00:45 044][HUB3-1][Err]--CheckFileRunState failed [20:00:45 056][HUB3-1][Err]--[0x10303004]Romcode/Switch status/Identify/Error result [20:00:45 056][HUB3-1][Inf]--Close device handle 0x000009f8
great rom! installed it with T95Q v1. seems all are working well. i had to make some remote.config changes to make my remote compatible. good thing total commander has SU access.
by the way, what code block that i can change to enable (hide and show) status bar? or is there an apk for it?
i want to use tincore keymapper for my gamepad but it needs the status bar to activate the keymapping.
cheers! many thanks to your efforts!
Any idea how to make the google assistant/voice command work on this ROM using G10 air mouse? air mouse and remote buttons are tested and working but when Mic button is pressed, google assistant will just appear but unable to pick up my voice.
to test if item is working, i downloaded sound/mic recorder and my voice is being pick up so the remote is working.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by raptur3d View PostAny idea how to make the google assistant/voice command work on this ROM using G10 air mouse? air mouse and remote buttons are tested and working but when Mic button is pressed, google assistant will just appear but unable to pick up my voice.
Hi first of all great rom.
Looks like everything is working well but have you adedd also minix remote? You had it in 8.1 ROM.
Back button is not workin in ATV system. In kodi i can make keymaps, but don't know how to do that in android itself to be available globally.
If i enable air mouse on minix remote then back button working fine so this is workaround but would be nice if it can work out of the box.
On that remote for it actually "ear" you, you need to keep the mic button pressed while you talk... is how that remote works.
There are currently 3643 users online. 0 members and 3643 guests.
