[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
hello .
?? ??Â
I install your rom, but I would like to put the latest stock version beelink 005P0.
??Â
but when i connect the box to my pc via the usb, the pc does not detect it, the box light comes on for 5 seconds and then goes off.
usb burning tool no longer does not detect the box, not even a few seconds. I use USB Burning Tool 2.1.7.3 and, before flashing this rom, I had no problem.
Do you think it would be possible to flash the last beelink via burn card maker? thank you.
EDIT:i have installed the rom on my usb stick with burn card maker and? i have flashed the stock rom via TWRP RECOVERY but my box is com in bootloops !!!? HELP PLEASE .
EDIT2 :i have resolve  Did it with the “reset button” and my computer finally found the device.
Another way, if all truly fails for you, Requires you to take apart the device shorting 2 pins, but putting it in Rom Mask Mode, will always get you out of any trouble and always allow
you to flash no matter how bad you might have messed up your box. I ran into a issue similar to this this one, Was locked out from changing rom back.. was stuck with a rom that
was bootloader locked and protected and no recovery.. and no matter how much I press the button in the back it would not show up on USB Burning tool.. and sdcard burn didnt work as well.
So I took the plunge and shorted out the 2 pins on eprom (after taking a day or 2 to find them) and USB Burning tool worked.. showed everytime..
I didnt wanna go though this over and over.. so I bought a momentary switch and solder it in to them 2 points.. Now I can just press that switch while putting in USB cable.. and no matter what.. allways have a full connection and can flash anything regardless.. Pretty much makes it unbrickeable..
hello
Can you help me how you solved EDIT2
There are currently 4332 users online. 0 members and 4332 guests.
