P.D: The GenericRom based on Android 8.1, worked for me without problems.
[ROM] Generic SC MultiWiFi S905x2 Pie ATV 20191004 *Fix*
Originally posted by saddas View Postsuperceleron
The link for new firmware not working
Originally posted by mega-samu View PostIn T95x2 the rom does not start. It stays on boot (the screen that says androidtv powered by SuperCeleron).
Well without serial debug log there is not much i can do
Yes, my tvbox is 64gb of rom. Using a usb-ttl could you connect the tvbox in series, right? If so, I try the weekend.
hmmm try this, flash the img as normal, then power it on and leave it alone for like 10/15 min if you can just to test something!
Your rom:
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
Stock rom t95x2:
P. D: I tried the normal one and it also did the same to me.
Here is the log via serial:
Your rom:
Stock rom t95x2:
Hi, light stays off when GT Mini box is on...and on when box is off...it happens on "fix" image too..Power definition defaults to sleep..changed to power off and box shuts down but cannot be turned on with remote...CEC not working...works fine on Beelink stock updated 9.0.. (9-25-19)..much prefer android TV...hoping it can be fixed..ThanxLast edited by freakkid; 10-20-2019, 19:50.
Originally posted by freakkid View PostHi, light stays off when GT Mini box is on...and on when box is off...it happens on "fix" image too..Power definition defaults to sleep..changed to power off and box shuts down but cannot be turned on with remote...CEC not working...works fine on Beelink stock updated 9.0.. (9-29-19)..much prefer android TV...hoping it can be fixed..ThanxLast edited by blacksnoopy; 10-05-2019, 02:30.
Report some bugs
Device: beelink gt-mini 95x2
1. Wifi proxy settings show an error when select none from manual(Can't save proxy settings when select none). I have to forget the ssid and reconnect.
2. HDMI-CEC not works fully. The gt-mini will wake up when TV turn on. But TV won't turn on when the box wakes up.(It works well on my shield tv. Box wakes up, TV turns on)
3.The light is wrong on GT-MINI . The light is on when the box is off, and the light is off when the box is on.Last edited by blacksnoopy; 10-05-2019, 08:38.
Guys, you need to read the title... it says generic.. i cant support all possible functions of all boxes out there, or it said in title a specific box...
Yes the led in GT1 mini is inverted, i will change it in a future build...
Yes CEC wont turn on the box, i disable it in uboot because of some bugs in not 100% compliant TV's (or bad FW on them).., that TV's with issues wont let the box go to sleep!
I will think if i enable CEC again or not.
There are currently 3112 users online. 4 members and 3108 guests.
