And scale in android box to 100%
justXBMC "new firmware for x7"
Originally posted by drsatan666 View Post
And scale in android box to 100%Everything is possible if we work together!
glad i could helpEverything is possible if we work together!
The files are in /data/data/com.flumpster.xbmcEverything is possible if we work together!
justBMC won' run stable
Hi!
I've a problem with my X7.
The minix freezes at least 1-2 per day and several times when updating the audio / movie library.
Any diagnostics software I can run? It seems justBMC runs better on other X7 devices. Perhapse mine is broken?
Second issue: when running Live-TV with "Add-on:VU+ / Enigma2 Client" and my Dreambox, Channel up / down "kills" xbmc and with some buttons, sleep etc I can get back to the homescreen.
Additionally, when I'm running live-tv and opening the menu, the stream begins to stutter. Performance issue?
1080p50 playing only with stutter
Dear all!
I have a MultiConsole (=Minix X7) and tried various firmwares (JustXBMC, Wasser, QS3, Miracle,...). The firmwares work really smooth - but I am not able to solve one problem: My homemade videos in 1080p50 will not playing correctly on any of the firmwares.
Problems are:
- stuttering
- and/or growing time lag between video and audio (video is playing more slowly than Audio).
Even if the videos are small (app. 50 MB) and directly on the SD card.
I have searched the forum for possible solutions - but didnt find any? Maybe anyone of you has an idea?
Thx in advance!
Regards
Oliver
P.S.: On my Raspberry Pi B+ with OpenELEC (a special XBMC version) the videos play perfectly....
CPU usage and performance issues
Hi all - wondering if I can get some help.
My x7 and JustXBMC has been running well for a while now. Over the past couple of weeks, I noticed that every now and then the UI becomes slow and if I check the CPU usage in SYSTEM INFO I see the CPU usage is quite high. Often when this happens the background images don't appear, etc. If i try to reboot from XBMC, it often stalls and I have to reset by pulling the power.
Has anyone else experienced this?
Also - yesterday when I had this issue occur, I rebooted and then when it booted back up, I was on the normal launcher, not XBMC. When I clicked the justXBMC icon on the home screen, it said it could find it. The app was missing. I then reinstalled it form the stand alone APK and when I rebooted, the unit kept going back to recovery boot screen (maybe I did something wrong). Anyway, I re-flashed JustXBMC. After a while, I got it all back up and running as I did before. However, the CPU issue is still occurring occasionally - and SAMBA/CIFS shares keep crapping out 5 or 6 times throughout a movie (mnted via busybox). This never happened before.
Is there some sort of diagnostics I can run to monitor what is using the CPU? I have nothing else installed apart from Root Explorer. In XBMC, just Pandora (rivy), XBMC Library Auto Updater and that is all(apart from the standard installed with ROM).
Anyone else had something similar happen?
Why not just disable all running services until they are need with greenify? That would certainly improve overall performance. Also be sure to install greenify paid experimental addon (to greenify system apps as well) and also install boot manager. You'll also need to install xposed. Then buy titanium backup that way once you get everything tweaked the way you like it, you'll never have to do any work gain and it's smooth sailing
Originally posted by Cantenna View PostWhy not just disable all running services until they are need with greenify? That would certainly improve overall performance. Also be sure to install greenify paid experimental addon (to greenify system apps as well) and also install boot manager. You'll also need to install xposed. Then buy titanium backup that way once you get everything tweaked the way you like it, you'll never have to do any work gain and it's smooth sailing
Will look into the other suggestions also - thanks!
Originally posted by drsatan666 View PostFantastic I will have a look into that. I have been meaning to install titanium as I have it on my phone. Just resetting XBMC up with only my shares and will run that a couple of days. If performance is good, it could be something I have done with my standard set up with XBMC.
There are currently 1944 users online. 1 members and 1943 guests.
