justXBMC "new firmware for x7"
Please reflash the firmware and try again.
Let me know if this solve Recovery not working.Everything is possible if we work together!
I will looking into it.
Can someone else confirm if CWM and ota is working for others?
Its working for me, thats why its a litle strange:"Everything is possible if we work together!
Solved NFS issue, not the way I wanted it - but it works at least.
NFS share is only accessable via wireless interface connection, if I switch to ethernet (rj45 straight-through cable to the router) it stops, but I can acces SMB shares or internet, can't figure out why as both interfaces accuire ip/netmask/gw through the same dhcp server...
Will check nfs conection tomorow and see if there is something i can do about it.Everything is possible if we work together!
Originally posted by Loser View PostI am able to reboot to CWM. I diid not have to reflash. Is there a version number I can look for to confirm if the ota worked and maybe I just wasn't looking when it flashed the ota?
Originally posted by stantheboss View PostHmm, maybe im doing something wrong, flashed via rockchip batch tool one img file, that's it.
Originally posted by stantheboss View PostYes, it does a full wipe (can be seen while flashing) so it's a clean install. How do you enter CWM, through settings->tools?Everything is possible if we work together!
Not sure why its not working for you than:"
If you are makeing clean install all should work out of the box.Everything is possible if we work together!
There are currently 2677 users online. 3 members and 2674 guests.
