justXBMC "new firmware for x7"
    thanks, glad you like it
    Everything is possible if we work together!
    ApkFreak
      skin was automatically changed from confluence modified to confluence 7 icons, how to get back to your modified skin, Lewy?
      can't find it nowere in any repo.
      RESPECT
        not sure why this happend.
        you can clear the data for xbmc in settings
        ApkFreak
          found the issue
          superrepo is puling the update on the skin.
          i will disable superrepo on next update.
          its shouldnt do the s... like this
          i will also spoof the skin to version 9.9.9 so this will never hapen again
          ApkFreak
            PROBLEM WITH THE LATEST AUTO UPDATE OF THE SKIN
            It has autopdated the skin with the confluence 7i cons and replaced that marvelous skin it has this justxbmc rom there is no shortcut of android anymore how can i put that custom skin of the rom again and disable the auto update of it?
              i will update the firmware soon.
              also will post the new apk soon that will take care of this spam update.
              ApkFreak
                about the skin problem
                if we disable the superrepo addon it would be fine?
                  ah. yes, it should be fine to.
                  also here is the skin zip witch should take care of this.
                  please try to install it from within xbmc and let me know if its working ok.
                  ApkFreak
                    it worked
                    I DOWNLOADED MANUALLY FROM SUPERREPO SITE ONLY SUPERREPO VIDEO ADDONS ... I DISABLED SUPERREPO ALL ADONS AND INSTALLED FROM THE EXTERNAL only superrepo video ADDON I DOWNLOADED SO IT WAS NO NECESSARY TO TURN OFF AUTO UPDATES
                      Thank you Lewy,
                      I have cleared data, and disabled superrepo.
                      It worked.
                      I have downloaded the skin you zipped to zippyshare.com but havent tried it.
                      It is the same skin that comes with v1.3.0 ??
                      RESPECT
                        if the skin on your device update by itself, just install the new skin zip on top of that updated one.
                        no need to disable superrepo after that (have in mind next version will dont have superepo and i 1chanel plugins)
                        its the same skin that is used by default in justXBMC just spufed to ver 9.9.9 to prevent something like this in future. hope it helps
                        ApkFreak
                          Thank you, it worked like a charm.
                            Glad i could help.
                            Also the next firmware update will be odexed to speed up boot times and optimize ram use.
                            Please google "odexed vs deodexed" to know what it mean.
                            ApkFreak
                              Glad i could help.
                              I can't wait for your new firmware. I tried them all and your Just XBMC works best for me . Nice , clean, with no unnecessary apps, XBMC orientated, just "my cup of tea".
                                Hi ,first thx for the "justXMBC" using it and i like it.
                                I want to confirm i have some APK
                                - justXBMCv4 (49mb)- with HDMI audio support or hack
                                - justXBMC (60mb) - yesterday ive downloaded new version i guess its 1.3 - but it doesnt have the HDMI Audio
                                What are the differences between those 2 versions? Thanks
                                PS: I cant use the FW version , cos i need other apps also..
                                Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
                                Video Out: Benq W1000+ 1080p Projector
                                Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
                                Remote: Rikomagic MK702 II, Minix NEO M1
                                Storage: NAS Zyxel NSA325v2
