Please post your findings and how you like the firmware.
justXBMC "new firmware for x7"
First post updated with new version.
Please post your findings and how you like the firmware.Everything is possible if we work together!
Of all the bloody days for you to release this, I haven't touched Beyond in over a month and released an updated version today. Typical.To Infinity and Beyond.... XBMC
heh. please try it and let me know how you like itEverything is possible if we work together!
/data/data/com.flumpster.xbmcEverything is possible if we work together!
Looks great. 1080p movies play smooth.
The only "problem" I found is switching resolution. I lost the internal sd memory until a further reboot.
Thanks Lewy
.xml files?
Originally posted by lewy20041 View Post/data/data/com.flumpster.xbmc
just wanted to know if both factorycore player and advanced settings are included within the above directory or if its integrated in the .apk...im not sure how to use external players (even after hours of reading on wiki lol), nor what settings to use with the x7.
can i use oc kernels from a diffrent fw? ex: https://mega.co.nz/#!DR1QGTpZ!63Osn-...TAf9ucuVyvtTEI available with the Quickshot v2 ROM???
and most important, what stock is your new version based on? I hope its 008
thanx again, and keep up the great work
Originally posted by Piratis View PostLook it does not boot at all it shows only the android robot it makes the installation and after it says booting it is not opening the box and after some minutes it is turned off ... Any suggestions ?Everything is possible if we work together!
Hi Lewy, I am using the Justxbmc apk under the hardwareguru rom because your version of xmbc runs best of all.
I only notice that some films and series on my HD drive force close the xbmc every time I run them. This does not happen on the other xbmc version, but those versions give me frame drops.
Most movies run fine. Any idea of what would be causing this?
All videos are 1080p with DTS.
I use justxbmc version 4.
Hi Lewy, I have been waiting for your XBMC update. It was a long time coming. I just flashed it and hate to ask this question. How to get rid of that bottom systembar? I put it to auto hide but in XBMC I can't get rid of it. I have been out of minix for a few months. When I saw your updated rom I thought I try. Could you tell me what I am missing? How do I get rid of the system bar? Thanks.
Originally posted by Vishwa Somayaji View PostHi Lewy, I have been waiting for your XBMC update. It was a long time coming. I just flashed it and hate to ask this question. How to get rid of that bottom systembar? I put it to auto hide but in XBMC I can't get rid of it. I have been out of minix for a few months. When I saw your updated rom I thought I try. Could you tell me what I am missing? How do I get rid of the system bar? Thanks.Everything is possible if we work together!
Hi Lewy,
I found the userfolder in the end, however copying over the old version meant that it no longer worked, so i've re-setup from scratch.
The great news is that all videos (both HD and SD) work a treat.
One issue however is if XBMC crashes for any reason the only way to fix it is a full restart, any chance you can add a 'restart xbmc app' to the long press power button menu?
thx
There are currently 1783 users online. 0 members and 1783 guests.
