I like the A2 keymap and the xbox 360 wireless controller keymaps both within android and XBMC best on Quickshot, they're hard to use on justXBMC...any ideas?
justXBMC "new firmware for x7"
Xbmc on JUSTXBMC is frodo very on quickshot you probably ising gotham witch handle xbox controler difrent. Installed xbmc gotham on JUSTXBMC and it will than work as in quickshot. As to android ui and games xbox controler should work nice at it Was tweaked for best compatibility with games and ui. So what is better in quickshot? Let me know and I will looking into it.Everything is possible if we work together!
Originally posted by lewy20041 View PostXbmc on JUSTXBMC is frodo very on quickshot you probably ising gotham witch handle xbox controler difrent. Installed xbmc gotham on JUSTXBMC and it will than work as in quickshot. As to android ui and games xbox controler should work nice at it Was tweaked for best compatibility with games and ui. So what is better in quickshot? Let me know and I will looking into it.
The android ui works perfectly with the controllers in justXBMC, although I'm still getting the hang of the keymap tool for touch games. I haven't had a chance to install emulators yet.
I'm actually hanging my new tv on the wall tonight, so after I should have a chance to play around some more.
Thank you for the great rom!
Please dont installed to much as new ver will be avilible in few days.Last edited by lewy20041; 13 June 2014, 09:36.Everything is possible if we work together!
First post updated with the new info and screenshots from v1.3.5
Ota (Over The Air Updates) is comeing!!!Everything is possible if we work together!
Originally posted by lewy20041 View PostFirst post updated with the new info and screenshots from v1.3.5
Once 1.3.5 comes out I'll TitaniumBackup all the apps and move over, I suppose.
Thank you so much!
By the way, are you using github for the source repos?
First post updated with new info and download link for v1.3.5.
Please, after installing this firmware write some feedback here.
Its realy apriciatedEverything is possible if we work together!
Its uploaded to mediafire.com so you shouldnt have any issues downloading.
I use chrome to and dont have any problem with downloading.Everything is possible if we work together!
Originally posted by lewy20041 View PostFirst post updated with new info and download link for v1.3.5.
Originally posted by drsatan666 View PostJust installing now form the previous version. I will let you know how it goes once I get set back up. Many thanks for all your hard work.
I did notice however that XBMC ran for the first time. I hadn't done anything, just allowing the Add-ons to install/update automatically. Unfortunately it went back to the old skin (confluence icons). I had to reinstall from the zip a page back to get your skin back.
Is it possible to have a 4th custom main menu button? I have been trying to run 4 smart playlists in the main menu, however as only 3 are supported currently I can't use them all. Not a big deal, but could be handy.Last edited by drsatan666; 21 June 2014, 02:42.
SMB Failure
Originally posted by lewy20041 View PostIts uploaded to mediafire.com so you shouldnt have any issues downloading.
Cheers,
DS
as to xbmc skinn issue, i added wrong ver of xbmc:/
realy sorry for that.
uploading v1.3.5v2 with xbmc fixed
and when it come to smb/nfs i always encourage people to use automount script in
/etc/init.d/ folder there are two scripts first is 97SMB and other 98NFS.
just edit the scripts, change ip for your shares there, and chenge permisions to 755 "rwx r-x r-x"
and reboot the device
your shares will be automaticly mounted in /mnt/Samba... etc
also you can acces them easly thru xbmc->video->files
hope that helps
edit:
firmware updated with fixed xbmc in first post, under the same link.
have funLast edited by lewy20041; 21 June 2014, 12:30.Everything is possible if we work together!
There are currently 3062 users online. 1 members and 3061 guests.
